Author Topic: Help with installing new coils?  (Read 1208 times)
Offline marsbound
« on: October 31, 2024, 05:30:26 PM »
I bought a new Charlie's Place coil set for my CB400F, but didn't realize I'd have to drill into my frame in order to mount it. Does anyone have/sell brackets for the Charlie's Place coils that can use the original mounting spot/hardware?
Thank you!
Offline BenelliSEI
  • 1969 cb750
Re: Help with installing new coils?
« Reply #1 on: October 31, 2024, 05:43:04 PM »
Ouch! Pictures might help?
Offline Mark1976
« Reply #2 on: October 31, 2024, 07:22:18 PM »
Thank you!
Gotta couple off questions,
1.   Are they dyna's?
2.        "      "      3 ohm?
The site shows dyna' and they're 3 ohm. If they are, you may want to take step back.
Start with the end in mind...
« Reply #3 on: November 01, 2024, 04:10:50 AM »
dont drill into your frame man to mount coils!!!figure out some brackets.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: November 01, 2024, 05:11:42 AM »
+1 to that!
Offline Mark1976
« Reply #5 on: November 01, 2024, 07:06:57 AM »
Thank you!
1.   Are they dyna's?
2.        "      "      3 ohm?
You can modify the honda coil mounts with very minimal work and use them, but if you're mounting 3ohm coils to a bike designed for 5ohm, you're going to have issues keeping the battery sufficiently charged.
Offline Deltarider
« Reply #6 on: November 01, 2024, 01:18:38 PM »
Thank you!
1.   Are they dyna's?
2.        "      "      3 ohm?
I happen to disagree. It's time to bust this myth that 3 Ohm coils are consuming so much more power. They don't. I have measured the amps and the difference is, mwah, neglectable*. Use the bike for what it was meant: start and ride! Avoid prolonged idling. Have a look in the Shop Manual Honda CB400F, in particular the chapter that covers the electrical and in p.62** you'll find specified that @5000 RPM (14,5V) the alternator is capable of 13A, btw the very same output I had deducted for the CB500/550 just the other day.
* http://forums.sohc4.net/index.php/topic,188181.msg2183788.html#msg2183788
** http://manuals.sohc4.net/cb350/service_manual/SM350400_2.pdf
« Last Edit: November 01, 2024, 01:35:02 PM by Deltarider »
CB500K2-ED Excel black
Offline marsbound
« Reply #7 on: November 05, 2024, 07:12:02 PM »
Here's some photos of the old coils and the new coils. Is there a "drop-in" replacement for the coils that I can use until I have the time to get these new coils mounted? I've got a milling machine but it's deep in the garage and not set up at all. Alternatively, is there someone that i can reach out to for custom brackets?
Thanks
« Last Edit: November 05, 2024, 07:14:01 PM by marsbound »
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: November 06, 2024, 04:45:33 AM »
Bolt down one end and zip tie the other?
Offline Deltarider
« Reply #9 on: November 06, 2024, 07:20:42 AM »
Won't work. Here's an experiment for anyone interested. Loosen the bolts that hold the coils, so that the coils are just a tiny bit free. Then start the engine and watch the coils moving wildly as if they want to break free (magnetism at work). Spectacle!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #10 on: November 06, 2024, 10:31:29 AM »
1/2" wide x 3/4" long tab in anything from 10ga to 16ga. Drill two holes in it, bolt one end to the stock coil bracket and bolt the other end to the new coil (you'll have to scrounge up a nut and bolt). The slotted holes in the new coil will be quite forgiving.
EZPZ
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #11 on: November 06, 2024, 06:48:57 PM »
Is there anything wrong with the stock coils?
« Reply #12 on: November 07, 2024, 12:23:05 AM »
ive run a boyer ignition with its coils for years,using the factory mounting points and made up some stand off posts.
Offline marsbound
« Reply #13 on: November 07, 2024, 01:36:36 PM »
Yes - the plug boots broke off :(
« Reply #14 on: November 07, 2024, 02:23:56 PM »
The boots screw onto the ends of the wires. Look inside and there is something that looks like a wood screw. Trim off about 1/4" from the wire and screw the boot back on. ;)
Offline marsbound
« Reply #15 on: November 09, 2024, 10:49:58 AM »
well...now that THAT problem is taken care of, what's the best way to screw in spark plugs after the crush washer is already crushed? I can't find any torque specs anywhere, and I'd really like to not crack my block or strip the threads as I'm trying to dial in my mixture!
Offline Deltarider
« Reply #16 on: November 09, 2024, 11:54:18 AM »
1,2 - 1,6 Kg/m (8,6 - 11,6 lbs/ft) But personally I would prefer my feel.
Online HondaMan
« Reply #17 on: November 09, 2024, 02:22:52 PM »
I just snug them down, about like a small 6mm bolt. They won't come loose.
For coils for the 750/500/550/400F/350F I use these:
#17-6823
from PartsNmore here:
https://www.partsnmore.com/parts/honda/cb750k/?filters[category]=electrical&filters[fitting]=custom&filters[page]=2
They are carbon-copies of the old TEC coils, electrically and physically.
