Author Topic: Suggestions for cleaning head & cylinders exterior?  (Read 1541 times)
Offline slyguy
« on: November 08, 2024, 02:37:38 PM »
I’d like cleaner prettier looking top end:)
Offline CBJoe
Re: Suggestions for cleaning head & cylinders exterior?
« Reply #1 on: November 08, 2024, 02:50:58 PM »
Lol...degreaser and water?
All joking aside, are you trying to clean painted material or are you trying to clean and paint fresh
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline kerryb
  • Not a very
« Reply #2 on: November 08, 2024, 04:01:13 PM »
Plastic brushes and degreaser.  I use a spray bottle of kerosene and a toothbrush.  After that I may just touch up spots, or strip for paint.  Bamboo barbecue skewers work great to pic dirt & grease out of the corners.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: November 08, 2024, 04:42:18 PM »
I use brass brushes, tooth brushes, engine degreaser, orange degreaser, etc.
Engine out of the bike or in it?
Offline britman
« Reply #4 on: November 08, 2024, 06:47:57 PM »
Clean it well, then paint. Dupli color engine primer and paint.  Very durable......
Offline Kelly E
  • Geriatric Hooligan
« Reply #5 on: November 08, 2024, 07:03:54 PM »
Sometimes I glue squares of Scotchbrite to paint stir sticks or make sticks with the table saw to scrub between the fins. Weather strip adhesive works good and you can peel off the worn pieces to glue fresh ones on.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline slyguy
« Reply #6 on: November 08, 2024, 07:20:49 PM »
That’s what I’ve done with mine, in fact almost identical to yours.:) My valve cover is shiny. Top end going together next couple weeks once YAMIYA/Riken order comes.
« Reply #7 on: November 09, 2024, 03:32:05 AM »
Preparation is the key to good painting results.
« Reply #8 on: November 09, 2024, 05:37:42 AM »
…… so glad that I can meet people on this forum that are as crazy as I am!
Offline slyguy
« Reply #9 on: November 09, 2024, 06:31:26 AM »
Wow, I too have a mint/original gray breather cover & tv adjuster I’ll be using.:)
Offline CycleRanger
« Reply #10 on: November 09, 2024, 06:52:48 AM »
I did this ten years ago or so. It still looks pretty good today.
Offline slyguy
« Reply #11 on: November 09, 2024, 05:03:40 PM »
Wow!🤩 nice job!
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #12 on: November 09, 2024, 06:07:41 PM »
about as long here too
« Reply #13 on: November 09, 2024, 07:26:59 PM »
Boy, Medyo: what is there to re-balance the right side of the bike? That's gotta be heavy!
« Reply #14 on: November 09, 2024, 08:31:10 PM »
Me too......a K4 motor from 4 years ago that I painted.....
And I drove 280 miles today to buy another to add to the project list...... a 1 owner bike. Man I have a problem......
« Last Edit: November 09, 2024, 08:35:38 PM by newday777 »
« Reply #15 on: November 10, 2024, 06:51:11 AM »
That was a photo of the sand cast on the engine stand? No fins on the oil filter canister.
Nice bit of history
« Reply #16 on: November 10, 2024, 08:23:23 AM »
Nice bit of history
Yes. #000582
Offline Honda Hansel
  • Sherwood Park AB
« Reply #17 on: November 10, 2024, 09:31:50 AM »
Hi
Been doing a bit of cleaning my self and found the best way (for me) is the steam cleaner
lots of steam and continuous steam
Add a bit of simple green and go to town add a tray under the engine that catches the small amount of water and grime and no mess in the shop
Gets right in to all the tight spaces and cleans out the oil and grime
cleaned my CB750K7 was a quick way of doing it and my CX500TC and my CX500C and a lot of parts
Honda Hansel
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
« Reply #18 on: November 10, 2024, 11:09:26 AM »
Hi
Honda Hansel
I've thought of buying a small steam cleaner to do the motors. Guess it's time for me to find one.
Offline CycleRanger
« Reply #19 on: November 10, 2024, 11:15:41 AM »
Hi
Honda Hansel
I imagine that really helps loosen the grease and the road tar from the underside.
  • Sherwood Park AB
« Reply #20 on: November 10, 2024, 12:01:05 PM »
steam cleaner and my Vapor blaster is my two best friends
Can't be with out
steam is the quickest way to clean and it removes oil and road grime
Honda Hansel
Honda Hansel
  • Gusto mo titi ko?
    • project
« Reply #21 on: November 10, 2024, 12:31:43 PM »
Hi
Honda Hansel
Looks great!
« Reply #22 on: December 01, 2024, 05:07:00 PM »
I've seen one "balanced" with a magneto on the right side.
« Reply #23 on: December 03, 2024, 12:10:55 PM »
Yeah, that would work!
:D
« Reply #24 on: December 08, 2024, 10:11:04 AM »
Hi
Honda Hansel
Never had a “steam cleaner”, and curious. Spotted this on Amazon. Watched the video and seems pretty impressive. Is this a typical rig? Under $100 or do you need more?
