Author Topic: How do you lift the world by your self from abow with overhead crane  (Read 675 times)
Offline Honda Hansel
  • Sherwood Park AB
Hi
Been looking to do this for a long time and had to wait till I got older
Young and stupid back in the early days .Not no more stupid lifting
Got a Barn door track's and hanger rollers from the hardware store and made the cross plates for the top of the trusses .Drilled and taped the flat bar 3/8" flat bar (strong enough for my use)
The track is bolted up under the sealing and bolted up with 3/8" bolts clamping the truss on the top
Best thing I have done in years
Honda Hansel
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
#8 1978 Honda CB550K
#9 1968 Kawasaki A1SS 250 cc Two stroke smoker
Online PeWe
Re: How do you lift the world by your self from abow with overhead crane
« Reply #1 on: November 10, 2024, 09:59:56 AM »
I need a crane too.  ;D
  • Sherwood Park AB
« Reply #2 on: November 10, 2024, 05:24:13 PM »
Well tested all ready and working
The track design is made so it cant spread apart and the rollers are also designed to run in the track
the roller's are rated to carry 400lbs per roller set and the rating on the track is also rated to carry 400 lbs over
4 foot span plenty strong for what I need
main trolley has 4 set of roller's so 1600 lbs rating
cross trolley has 2 set of roller's so 800 lbs
My max capacity is 1/4 ton
I have no concern's about the structural design
my max lifting capacity calculated by the structural engineer was easy 800 lbs
more then I need
Big barn doors are heavy figure out a door weight of a 10 X 16 door on a machine shed
Honda Hansel
Honda Hansel
« Reply #3 on: November 10, 2024, 07:38:34 PM »
I like it…
I don’t know what tracks and trolleys you bought. I can attest the barn doors I have are very heavy.
I’ve seen my doors nearly straight out in a wind storm. Had to use a jack to lift one door end to get one of its trolleys back on track when the stop broke from years of abuse.. I’m sure your new door track and bogies’ published  weight specifications are conservative compared to actual failure tests.. old stuff used to have a 200% cushion… especially overhead ratings…
« Last Edit: November 10, 2024, 07:42:02 PM by Tracksnblades1 »
« Reply #4 on: November 10, 2024, 08:48:06 PM »
Looks great to me! The weight of that engine is shared equally across four points, so really not even much of a load. Brilliant!
« Reply #5 on: November 11, 2024, 03:18:01 AM »
That looks great HH.
It looks like it moves in both directions? That will make it easy to maneuver the motors to take out and put back in the frame. I like it.
Unfortunately I don't have the ceiling height in my shop to utilize that system, so I will continue with the hoist crane from the floor(after I make a C hook).
