The petcock is leaking on my K1 tank, but only when the lever is in the off position....
Just curious Steve, but is your petcock leaking fuel out of the petcock itself? Or is it simply not shutting off the fuel to the carbs when in the off position?
ZT
The petcock is leaking out of the lever area when turned on, it is still working properly when in the off position. It's an odd issue that I have not seen before, I write it off to the the nasty ethanol fuel.
Hey Steve, I came back to this thread to post what I've learned about my petcock problem. And I'm not trying to ruffle your feathers on this, and please correct me if I'm mistaken; but I think I quoted your original post accurately. That's what tuned me into this thread in the first place... I.E. A petcock leaking in the OFF position.
You may wish to go back and edit your OP so as not to mislead anyone else about your petcock problem.
And here...
Has this problem (weeping petcock - when off) fixed itself? Or is the slow dripping fuel evaporating before it reaches the end of the drain line? Or am I missing something else?
ZT
I do not have a leaking petcock when in off position. If I were you and had a leaking petcock after a rebuild, I would spring for a new genuine Honda petcock...
Sorry if I wasn't clear Steve, but here I was referring to my own (weeping petcock - when off) problem... not yours; which I understand is pretty much sorted out now. Good job!
Appreciate your reply Steve but I don't really think I need a new petcock.
At this point, if I notice any more leaking (through the carbs) with the petcock off, I'm more inclined to use or drain the fuel that's currently in the tank, remove the side hold down plate and lever, and replace the aftermarket 4-hole rubber seal with an OEM seal. Then see what happens!ZT
Did you replace the fiber sealing washers that are under the screws holding the petcock to the tank? The will cause leaking in the off position into the bowl, then into the carb hoses, filing the carb bowls
Not sure if I used the new washers in the kit or the original fiber washers; but the petcock has been on both the old and new tanks, on and off the bike with gas in it, and was not leaking or weeping gas out the exit ports in the Off position.
And it doesn't seem to be leaking now! So I'll watch this and if I see a problem will try an OEM rubber seal/valve.
ZT
Stu, Now that I've dug into my petcock again, I need to correct my previous answer. I remember wanting to use the OEM fiber washers during my rebuild, but after digging in to my old parts, remember now that one of the fiber washers was broken, so I used the crush washers provided in the 4into1 kit... which may not be doing the job.
I've wondered if the vinton seal for the GL1100 petcock would fit.
https://www.randakks.com/gl1000-gl1100-petcock-repair-kit-included-in-gl1000-and-gl1100-master-kit.html
I'll be able to give you some feedback on the viton seal pretty soon. Here's what I've found...
![](https://i.ibb.co/Xb2x5Cg/Petcock-Parts.jpg)
Here, you can see on the left, the original OEM petcock parts I removed several months ago when the petcock was rebuilt with the 4into1 kit.
As described, while cleaning a clogged pilot jet, I noticed I needed to prop up the float to stop fuel at the needle jet with the petcock turned off. I also noticed the lever was very stiff and suspected modern fuels had swollen the 4into1 four hole seal.
Surprisingly the seal looked fine and, at this point, I do suspect the fuel is leaking into the bowl via the threads of the mounting screws with the 4into1 crush washers.
The stiff lever, I found, was due to some congealed "Fuel Lube" I thought might be a good idea to use. Apparently not. The creamy lubricant had thickened up and congealed to where it was impeding rather than faciltating movement of the lever.
I won't be using the "Fuel Lube" when it goes back together but does anyone use some sort of lubricant on the petcock lever?
and whilst the bowl leak has stopped you may find that the fuel can all be consumed without switching to reserve...
John
I plan to find out soon John. My plan is to put the petcock back together and see if I can ride with petcock ON with only a reserve amount of fuel in the tank. If it does, I'll pull the petcock and swap the 4into1 crush washers for some new fiber washers.
Which brings me to the last two things I wanted to mention. First is an ebay seller...
https://www.ebay.com/itm/156435081134... who claims to sell identical fiber washers, from the oem supplier IIRC. A bag of 5 for $7 with free shipping in lower 48. Not bad if they work! I see OEM Honda seals for $5 - $10 each. These look right and I have a bag on the way. If my road test confirms the bike does run with petcock ON with only reserve fuel aboard, I'll change out the washers.
Lastly, as to Oddjob and others brainstorming the four hole viton seals, I can tell you the viton seals from Randakks/Dime City are identical in size and shape to the OEM Honda seal as well as the 4into1 seal.
Randakks charged $7.80 for a viton seal and $5.01 for OEM Honda seal. I got one of each. I'll try the viton seal first and report any problems.
And once again, does anyone lubricate the circumference of lever disk or the inner face of the lever disk with anything?
ZT
