Author Topic: K1 petcock rebuild kit?  (Read 582 times)
Re: K1 petcock rebuild kit?
« Reply #1 on: November 12, 2024, 09:13:53 AM »
There is no "kit" you buy the circular seal, bowl O ring, petcock to tank O ring, fuel strainer and not forgetting the special fibre washers for the holding screws all as seperate parts, not sure if you can getvthe wavy washer seperate
Offline Nurse Julie
« Reply #2 on: November 12, 2024, 09:36:14 AM »
This is the kit I sell.
Trust me I'm a Nurse, I promise it won't hurt....much
Offline CycleRanger
  • No comment about being an
« Reply #3 on: November 12, 2024, 09:48:26 AM »
4into1 has a kit as well.
https://4into1.com/petcock-rebuild-kit-honda-cb160-72-77-350f-500k-550k-750k/
CB750supply has the whole petcock for ~$35. (repop)
https://www.cb750supply.com/search/?q=CB-70407
Scrambler Cycle has a kit too.
The round gasket is also still available from Honda.
pn 16955-268-020
« Last Edit: November 12, 2024, 09:52:37 AM by CycleRanger »
« Reply #4 on: November 12, 2024, 09:59:28 AM »
Sorry, should have said there is no Honda part number for a "Kit".
Out of the alternatives i would use nurse julies, just add the two thick fiber washers for the screws holding petcock to tank.
Theses are a non standard size, extra thick and expensive as Honda parts
« Reply #5 on: November 12, 2024, 08:36:36 PM »
Steve-O, be sure to tear down, clean and inspect the petcock you have now before buying just the 4 hole rubber...I have seen Petcocks that were corroded internally and would not seal no matter what.  Also sometimes all they need is to have the wavy spring sort of re-tensioned or also sometimes flipping the four hole rubber so it faces the other way (Just flip it over!) can get them sealed up again.
« Reply #6 on: November 13, 2024, 06:59:13 AM »
Hi Julie..that is what I need but prime riding season here in Texas is now, dont want to wait for a package from the UK.  Thanks though...
« Reply #7 on: November 13, 2024, 07:11:24 AM »
pn 16955-268-020
Hey Ranger...I did see that on 4into1, but am leery buying anything but genuine parts from them.  And I've had bad luck with re-pop petcocks in the past, not going there again. Did not know the gasket was available, thanks!
Going to go against Sean's sound advice and just order the valve gasket but will slightly tweek the wavy washer too.  Highly doubt the petcock is corroded inside.   Thanks all
https://www.ebay.com/itm/305671595089?_skw=Honda+NOS+16955-268-020&epid=1437277520&itmmeta=01JCK0Z4GMWG2JK6AK9MXNDSPH&hash=item472b726451:g:hCcAAOSwZLBmkjnp&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKl58%2Bx4K6uLR4lO%2BsrArWZoBITGdvO1WDNv8Mz1KlSf01%2BC%2F0PjBVd73r1b%2FiWtS%2BrFsagTr7SlUTWF3VnjZJY7IMFWxhPpihUL5l%2Bo8pIjWzVl2KxjqLoD37UgIAMiz6Iun6VfHTedjlKyyJUyiGxRWw%2BFtqwoF1PugFqP2tb5fcdbuC1647baKI53ViTH%2F4Tefso7iglZKcP0sIfI2xcYABE36jwXQHP5v5D%2FFbpbrvNKOShS9I5kTjiX6JIwuV5uGLGkQbyLu3taMZBuAqfWHlo4xIF7bgtuqBbC501jAw%3D%3D%7Ctkp%3ABk9SR7LI_ODkZA
Offline CycleRanger
« Reply #8 on: November 13, 2024, 08:57:01 AM »
Sounds like a plan.
It's best to try to change that round gasket without removing the petcock entirely so not to disturb the other gaskets.
Imho that petcock is a poor design the way it seals to the tank.
Honda must have agreed since they changed on the later bikes.
« Reply #9 on: November 13, 2024, 09:05:07 AM »
Yes, my plan is to remove the tank but not the petcock from the tank. There's not much gas in it so I can tilt it so I dont have gas leaking all over when lever is removed.  Gasket ordered...
Offline ZTatZAU
« Reply #10 on: November 13, 2024, 10:44:53 AM »
The petcock is leaking on my K1 tank, but only when the lever is in the off position.
Just curious Steve, but is your petcock leaking fuel out of the petcock itself?  Or is it simply not shutting off the fuel to the carbs when in the off position?
ZT
« Reply #11 on: November 14, 2024, 07:24:25 AM »
ZT
The petcock is leaking out of the lever area when turned on, it is still working properly when in the off position. It's an odd issue that I have not seen before, I write it off to the the nasty ethanol fuel.
« Reply #12 on: November 14, 2024, 07:38:35 AM »
ZT
It's actually the wet-swell and dry-shrink action from the ethanol that causes the big 4-hole rubber part to shrink, leading to the 'weeps'. If you add an ounce or two of [any] oil to the gas in the tank when you fill it up, it will prevent (or at least reduce greatly) this shrink-expand cycle. It happens with lots of these older bikes with the 4-hole petcock seal.
There is also some facial wear on that seal from the years of use, and especially from when it was parked for a LONG time, then the lever was turned again. That one action tore the tiny raised ridges around the 4 holes, against the lever face. That's why sometimes just flipping the rubber gizmo over will make it work again for a while. Sooner of later the fuel will also start weeping out the back side of the hole(s) again, usually after the bike was parked for the winter and revived the next Spring. Then again, as the seal gets softened by the ethanol it starts to seal again.
Nasty cycle. ethanol on buna... ;)
« Last Edit: November 14, 2024, 07:20:07 PM by HondaMan »
« Reply #13 on: November 14, 2024, 07:54:37 AM »
ZT
It's actually the wet=swell and dry-shrink action from the ethanol that causes the big 4-hole rubber part to shrink, leading to the 'weeps'. If you add an ounce or two of [any] oil to the gas in the tank when you fill it up, it will prevent (or at least reduce greatly) this shrink-expand cycle.
Yes, I had hoped that the leak would stop once it got wet from fuel but I guess it had shrunk too much.
I may try the two-stroke oil trick, I have a gallon on the shelf that I use in my Kawasaki H bikes, thx.
Offline Oddjob
« Reply #14 on: November 14, 2024, 07:58:42 AM »
I was experimenting for a while to see if I could make the 4 hole seal out of Viton, so it would be resistant to the ethanol, the problem was the thickness of the sheet, too thin and it leaked and the next size up was too thick for it to fit with the plate over the top. I was planning on seeing if I could plane a small piece of the viton sheet down to the correct thickness but other projects happened and the idea got shelved, still got all the stuff so I may restart it someday.
Offline ZTatZAU
« Reply #15 on: November 14, 2024, 08:06:16 AM »
Interesting!  I rebuilt my petcock during the early stages of my K1's resurrection and think I used the kit from 4 into 1.  It seemed to work fine.
However, when I had the #4 bowl off the other day to clean out the slow jet, I noticed I had to prop up the float to close the needle valve in order to keep fuel from flowing through the carb... even with the petcock in the closed position.
I also noticed the petcock is a little stiffer going into and coming out of Closed than it is going to and from Open and Reserve.  I figured there must be something going on with the four hole rubber valve/seal and bummed that I need to take it apart again to see what's going on.
When the bowl was in place without the flexible drain tube attached, the drain fitting dripped once every 30 seconds or so with the petcock OFF.  But now that everything is back together, I see no more fuel dripping from the bottom of the flexible drain tube.
Has this problem (weeping petcock - when off) fixed itself?  Or is the slow dripping fuel evaporating before it reaches the end of the drain line?
Or am I missing something else?
ZT
« Reply #16 on: November 14, 2024, 08:22:52 AM »
ZT
I do not have a leaking petcock when in off position.    If I were you and had a leaking petcock after a rebuild, I would spring for a new genuine Honda petcock.
https://www.ebay.com/itm/272332113104?fits=Year%3A1971%7CModel%3ACB750&_skw=cb750+1971+petcock+rebuild+kit&epid=1011843723&itmmeta=01JCGM71Y82NFMWZMB2F9448M6&hash=item3f684244d0:g:gFoAAOSwZ2FlLqdd&itmprp=enc%3AAQAJAAAA4HoV3kP08IDx%2BKZ9MfhVJKmTkfbPcJ3TUDz%2FhUh6ozmcxSdIWZ9ZfT0P%2B%2B%2BvmkrQ%2BCsAP%2BihQDknvDYg%2F17gmtKZF5scKIpc4T%2FjRfOoqK0Qlm8VUcHKgd6zJ4%2BvUP6ReFGAG5Y8Bt3yJwvCsfaJXLXv9B5GkiLn4a6LEGtZq77a05T3EfKLIaicJ3LQPJarrybTnSBmxfISu5zNC96wmWmVB1UlhtwZmzbaNDJQqBR%2BO2T%2FOVK1ZjLl8V5qTnHQIilbNVg7aK1%2FvDMOFzp%2BBWxLlYrXU5OXmfxpOWjtMUoC%7Ctkp%3ABk9SR56fnJTkZA
I have an attached garage and a wife that is a "super smeller", if she smells gas, I hear about it immediately! So, I cannot have fuel leaks to keep the peace.
Offline ZTatZAU
« Reply #17 on: November 14, 2024, 09:49:09 AM »
Appreciate your reply Steve but I don't really think I need a new petcock.
At this point, if I notice any more leaking (through the carbs) with the petcock off, I'm more inclined to use or drain the fuel that's currently in the tank, remove the side hold down plate and lever, and replace the aftermarket 4-hole rubber seal with an OEM seal.  Then see what happens!
ZT
Online newday777
« Reply #18 on: November 14, 2024, 10:11:51 AM »
ZT
Did you replace the fiber sealing washers that are under the screws holding the petcock to the tank? The will cause leaking in the off position into the bowl, then into the carb hoses, filing the carb bowls
Offline ZTatZAU
« Reply #19 on: November 14, 2024, 10:21:28 AM »
ZT
Not sure if I used the new washers in the kit or the original fiber washers; but the petcock has been on both the old and new tanks, on and off the bike with gas in it, and was not leaking or weeping gas out the exit ports in the Off position.
And it doesn't seem to be leaking now!  So I'll watch this and if I see a problem will try an OEM rubber seal/valve.
ZT
Offline Oddjob
« Reply #20 on: November 14, 2024, 11:58:33 AM »
Remove the fuel lines from the tap, if the tap is leaking you'll see fuel dripping from the outlets. The fibre washers sit under the heads of the mounting screws and if they are old and used it's possible they'll start to leak as they get older. If so the tap will leak even in the closed position as fuel is leaking down the threads of the screws and into the fuel bowl.
Offline ZTatZAU
« Reply #21 on: November 14, 2024, 03:38:04 PM »
Thanks Oddjob!  I appreciate your reply.
ZT
Offline jonda500
« Reply #22 on: November 14, 2024, 05:21:57 PM »
and whilst the bowl leak has stopped you may find that the fuel can all be consumed without switching to reserve...
John
A starter clutch thread:
« Reply #23 on: November 14, 2024, 07:20:55 PM »
That's ambitious!
« Reply #24 on: November 14, 2024, 07:24:05 PM »
ZT
Yeah...that happens on the PD carbs with the single-hose feed from the tank: it is siphoning the fuel from the pipeline and the other bowls until one of them 'breaks' the suction with a bit of air getting into that one's float valve. It's not unique to the 750: the 550 does it, too, on the later carbs with 1-hose feed.
