so the last times here i had 2 outside pipe temps like 100 or 200 degrees warmer than the 2 inside pipe temps (at the first bends,) on a recent 10k bike that i checked the camchain tensioner and removed the cam cover to glance at the tops and to check head bolts. got a bunch of suggestions but decided to wing it and after a 1k mileage flipping over, the problem stopped 1k before, soon as i stopped checking the temp. pretty sure nothing has changed, except worrying about it. runs great.
only the clutch is working smooth when cold and when it gets warm doesn't seem to be disengaging well from 1st to neutral, or even 2nd to neutral, until it cools to room temps.
when i picked it up from setting outside for maybe close to 20 yrs in the rain and leaking brake fluid res, landing on the #4 header, and other than rust, healthy rust, growing on various surfaces the one place that was showing the most weakness of that rust was the lower clutch cable spring inside the triangle cover. the water level was evident with a line that crossed the lower spring loop that was below that waterline, and gone from the rust, although the pushrod was above that water level, showed no signs of leaking, oil looked fine, other than resembling 90wt and only 2 quarts low. with a single written recorded oil change in the manual at
mileage 2617 on 9-14-80 with 20-50w castrol oil change. written exactly like that. it's all that was in the notes part of the manual. i picked it up at 9,500, i ran a couple of quick oil and filter changes with hondalube 10w-40sj and stayed with that 1000 miles later it's running good. the cable was corroded seized and i worked it for a few days and it's been working ok from when i got it. freeplay is good only it's at the last of the cable adjustment, adjusting it tighter looses the freeplay. the shifter lever looks like it hit something, it has a weird twist to the factory weldjob, not the adjusters nor the shaft pinch lever-they look fine, it seems to the necessary travel up and down. hopefully this description will point to the narrowed down suspected problems = when warmed lower gears tough to find, first to neutral while running. engine stopped no problemo. thanks
