Author Topic: Piston Ring Compressor for Inline Fours?  (Read 2547 times)
Offline Dr. Frankenstein
« on: November 12, 2024, 03:18:35 PM »
Anybody know of a good piston ring compressor to use on inline four motorcycle engines? Once I get the head back on my 500/4 it might be kind of tricky getting all those pistons back in their holes.
Offline M 750K6
Re: Piston Ring Compressor for Inline Fours?
« Reply #1 on: November 12, 2024, 03:33:34 PM »
Clean and everything well lubricated, I was able to lower the barrels on my 750, just using my fingers to guide the pistons and rings in. They didn't just drop in, but it wasn't too fiddly.
Online bryanj
« Reply #2 on: November 12, 2024, 03:44:26 PM »
Care and a small screwdriver, there is aig lead in on the sleeves of the fours unless they have been very overbored
« Reply #3 on: November 12, 2024, 04:07:45 PM »
I have a set of hose clamps (virgin) of which I sanded off the little ridges and sharp edges of the screwdriver slots to protect the rings. I use them for all the SOHC4 engines.
Avoid the hose clamps that have a thin metal band in between the threaded-slot band and the hose it would contain, as those thin bands will simply slide out of position when the cylinders are pushing down on the hose clamps. This prevents the rings from going in and also scratches the bore! (Don't ask how I know this, I won't tell you...). ;)
Online seanbarney41
« Reply #4 on: November 12, 2024, 08:20:40 PM »
uhhh, you are gonna need those ring compressors BEFORE you put the head on...and Hondaman's method worked for me and also just do 2 pistons at a time, center 2 first
« Reply #5 on: November 13, 2024, 12:38:32 AM »
You can make the "compressors" yourself. All you need is a strip of that thin metal used on shipped goods, often found in the streets. Cut it to the right size and then bend it into an open ended circle.
« Reply #6 on: November 13, 2024, 01:34:30 AM »
As in banding straps found on lumber bunks and steel shipments? Are they wide enough?
« Reply #7 on: November 13, 2024, 03:50:37 AM »
Yes, I have seen them being used. Should have taken a pic. Long time ago, long before cell phones with inbuilt camera's. They looked like this.
« Reply #8 on: November 13, 2024, 06:34:59 AM »
+1 hose clamps method
I also have a pair, carefully cleaned up and smoothed. I keep them in a bag in a tool drawer
Offline Bodi
« Reply #9 on: November 13, 2024, 02:13:10 PM »
All the fours I've done this on the barrels have a chamfer on the bottom that makes it pretty easy to get rings in with my fingers. Haven't done a 750 though. And on the 400 with a 466 kit overbore there's not much chamfer left so I used brass shim stock and cable ties to tighten it to where they would just slide.
« Reply #10 on: November 13, 2024, 06:28:35 PM »
I've done the brass shim stock, too, on the big-bore 750 engines, but inside of the hose clamps I usually use. Without the bevel on the bottoms of the cylinders, it's testy to get them started!
Funny thing is: I have both the standard-to-1.00mm overbore Honda ring clamps and the ones for the 836 big-bores. The hose clamps work better, by far.
« Reply #11 on: November 13, 2024, 06:48:13 PM »
Blue point has manufactured these for as long as I’ve known..
They work very well.. or you can make your own as Delta mentioned..
I’m not sure how big of bores they make bands for..
I have a homemade band for 6.500 + 0.125 inch..
If you need to borrow it for your build 🤫
https://b2b.snapon.com/productDetails/635923/2/885254
Online dave500
« Reply #12 on: November 13, 2024, 11:32:26 PM »
if you look close at those tapered lead in ramps they are pretty rough,ive sanded down and almost polished them smooth and it all goes real easy!
« Reply #13 on: November 14, 2024, 01:13:55 AM »
Small engine plastic ring compressor bands work on the smaller SOHC4 s. Recall a few years back folks using a set molded in red plastic....
« Reply #14 on: November 14, 2024, 04:47:12 AM »
Never having used one before, esp on an inline four, how does it work? Do you do one piston at a time, or put one ring on all four and work them in at once, or...? I've done plenty of two-cylinders, working each one in by hand, but that of course takes a while so I'm trying to step up my game here...particularly with the hose clamps - I assume you just remove the screw and then bend up the stem to allow you to manipulate it, yes...?
« Reply #15 on: November 14, 2024, 04:54:09 AM »
Two cylinders at once... Generally 2&3 first then 1&4
« Reply #16 on: November 14, 2024, 07:45:15 AM »
Like Rafster said...I'll tighten the clamp on the 2-3 first, then release the screw about 1/4-1/2 turn as I tap the cylinders down onto those 2. Then I put the clamps on the other ones and repeat.
I also made some flat [mine are brass] pieces to help hold the pistons squarely to the face of the engine itself so the tops of the pistons are held square to the cylinders. I can make pix of them tonight if you care: I slide them underneath the pistons opposite the camchain-hole sides of #2-#3 and the outer sides of #1-#4, and remove them after the rings are in all 4. This brass is 0.040" thick, not flexible (from the local Ace Hardware).
« Reply #17 on: November 14, 2024, 09:23:35 AM »
Yeah, pics would be great! I'm sure I'm not the only one who'd like to see that...and the brass is available at Ace Hardware?
Offline Dime
« Reply #18 on: November 14, 2024, 12:38:14 PM »
Would definitely like to see that as well HondaMan.
Online seanbarney41
« Reply #19 on: November 14, 2024, 04:15:04 PM »
I made mine out of some nice hardwood
« Reply #20 on: November 14, 2024, 07:38:05 PM »
Here's the ring tools, CB750 size.
The notches clear the cylinder studs and hold the piston stabilizers (that's all I can think of to call them?) in position while you fiddle things around.
The bars sit under the pistons to hold them square to the bores and cases.
They are about 3/4" wide, 0.040" thick brass strip from Ace Hardware (K&N Brass).
They are shown as they would be installed: #4 on the left and #1 on the right, as you will be facing the engine.
The 2 outside ones (#4 and #1) are flat because it's easy to get your fingers in to remove them (last), while the 2 inner ones (#3 and #2) have little bent tabs to help your fingertips or needle-nose pliers to nab them for removal after the rings are in the bores.
« Last Edit: November 14, 2024, 07:41:23 PM by HondaMan »
« Reply #21 on: November 14, 2024, 07:40:59 PM »
Offline Oddjob
« Reply #22 on: November 15, 2024, 05:29:45 AM »
Weren't the genuine Honda tool for holding the pistons upright much thicker Mark, I seem to recall them holding 2-3 right at the top of their stroke and just sliding under the skirt, seem to recall they were around 3/4" or thereabouts thick and just a slotted U shape.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #23 on: November 15, 2024, 05:30:43 AM »
I’ve always used my finger tips. For some reason closing my eyes helps me see things better when sliding the barrels over
Online bryanj
« Reply #24 on: November 15, 2024, 07:07:08 AM »
Yes the original piston holders went round the rods
