Author Topic: Hitachi bullet terminals and connectors  (Read 1006 times)
Offline leovich
« on: November 14, 2024, 01:55:24 PM »
Hi everyone, I want to share with you that I found a smart Japanese guy on eBay who can sell the Hitachi Hero bullet terminals and the 4 and 6 block terminals as used on our sohc’s bikes original wiring harness. This stuff is produced by Hero in Japan and marketed by Hitachi, it is the same as you can still buy from Honda but at a much lower price. I have both the connectors in honda bag and these hitachi connectors and they’re the same, on the Honda ones you can see the Hitachi/Hero sticker behind the Honda sticker.
These electrical stuff is far better than all the Chinese replicas you can find pretty everywhere now at a price that sometimes is lower than Chinese ones.
Can I write here the link of this shop?
Re: Hitachi bullet terminals and connectors
« Reply #1 on: November 14, 2024, 02:12:30 PM »
Please post the link on the ebay board. :)
http://forums.sohc4.net/index.php/board,33.0.html
« Reply #2 on: November 14, 2024, 05:47:09 PM »
Sounds like the owner of Vintage Connections
« Reply #3 on: November 14, 2024, 07:56:32 PM »
I use a LOT of the Vintage Connections' contacts and plug terminals.
They also have crimpers to die for: MIL-grade ratchet crimpers for a Honda-like cost. I use them on the gizmos I make for these bikes.
Offline leovich
« Reply #4 on: November 15, 2024, 04:55:09 AM »
I don’t know if vintage connection sell the original Hitachi parts, I never bought from them, but before I always used connectors and terminals from Honda, and Honda sell in fact this Hitachi parts rebranded with a Honda part number sticker on them. The advantage is that buying this same parts directly from Japan is a lot cheaper than order them from Honda especially if you use a lot of terminals
« Reply #5 on: November 15, 2024, 05:18:18 AM »
How do their prices compare to Vintage Connections, would take a little work to calculate if comparing against their kits...
« Reply #6 on: November 15, 2024, 06:34:37 AM »
Nice stuff.
Offline leovich
« Reply #7 on: November 15, 2024, 12:43:28 PM »
I paid 2,3 $ each pack of 10 terminals. I don’t know how much they’re priced at vintage connections but these are the genuine top quality ones, not replicas and can withstand the high current especially at the key switch connector
The seller is Japan-net-shop on eBay
« Reply #8 on: November 15, 2024, 10:48:42 PM »
$5.49 for 25 male or female 3.5mm single bullet connectors, just the brass, nothing more. The insulators are sold separately. They don't offer them in 10 packs.
At that price, Vintage connections is selling them for $2.196/10 Plus shipping
I did search for Hitachi 3.5mm bullet connectors and Hitachi connectors and didn't find the seller or the connectors. But I am using the eBay app...which I am not fond of...at all.
Offline Rayzerman
« Reply #9 on: November 16, 2024, 09:53:13 AM »
Not finding anything on Japan Net Shop either.... Vintage Connections are hollow bullets..... the OEM's are solid type.
Offline leovich
« Reply #10 on: November 16, 2024, 01:44:20 PM »
Yes very old OEM’s was solid type, these were superseded by the crimp type hollow ones. In the first picture you can see the bullet terminal now sold at Honda, in the second picture at the left top the sold by Honda spade terminal , right top the Hitachi/Hero branded terminal and as you can see they’re identical. The lower ones are made by Sumitomo
« Reply #11 on: November 16, 2024, 04:22:24 PM »
I found japan-net-shop ( needs the hyphens) BUT they only listed kits at over £100 and they did not include the multiway blocks
« Reply #12 on: November 17, 2024, 12:52:05 AM »
I also found one kit only.
I need separate bags of pins and sockets.
The cheap chinese can not be trusted. The socket can open up if bent just a little due to the thin flimsy metal.
« Last Edit: November 17, 2024, 01:09:37 AM by PeWe »
Offline leovich
« Reply #13 on: November 18, 2024, 12:07:22 PM »
Yes you’re right you can’t trust the cheap ones. To have this stuff you need to ask him because he has not listed. I’m trying to attach the Hero catalogue with the parts number
Offline leovich
« Reply #14 on: November 18, 2024, 12:12:37 PM »
Yes he has only in list the repair kit, it’s the same kit sold by Honda times ago. To have the single part bags you need to write to him, I attached the PDF from Hero with the parts number so you can see what you need.
I had a good business with this guy, you can trust him
« Reply #15 on: November 19, 2024, 03:47:30 AM »
Good info.
Maybe a new contact housing the CB750 rectifier has can be found.
Offline leovich
« Reply #16 on: November 19, 2024, 01:49:03 PM »
Good info.
Yes I bought also the 6 pin block connector without the locking pin as the oem one with the terminals because I want to rebuild mine too
Online Tim2005
« Reply #17 on: November 21, 2024, 12:31:21 PM »
Are these the Chinese 3.5mm terminals that aren't very good? I was looking for some & there aren't many 3.5mm options around
Offline leovich
« Reply #18 on: November 23, 2024, 08:20:59 AM »
These seems to be the Chinese ones, you can find this box with many brands on Amazon but it’s the same, their material is thinner than genuine ones.
But if you’re located in US and you need only few pieces you can also order at a Honda.
I attach the sheet with part numbers
« Reply #19 on: November 23, 2024, 12:30:38 PM »
Are these Honda numbers?
Online Tim2005
« Reply #20 on: November 23, 2024, 12:46:39 PM »
Great, many thanks for the part numbers chart
Offline leovich
« Reply #21 on: November 23, 2024, 01:18:27 PM »
Yes it’s a Honda bulletin, if you’re interested I attach the complete bulletin in PDF, but these parts can be ordered only from US Honda, a friend of mine that live in the US ordered that stuff for me this summer because it’s not possible to order these in Italy where I live.
« Last Edit: November 23, 2024, 01:21:30 PM by leovich »
« Reply #22 on: November 23, 2024, 03:00:30 PM »
If its a genuine Honda part number you should be able to order from any Honda dealer anywhere BUT you may have to buy the "packet" quantity and wait many weeks.
I ordered the US model guide by part number from a UK dealer and it arrived 4 weeks later
« Reply #23 on: November 23, 2024, 10:42:41 PM »
CMSNL has them. Just type in the partnumber.
Offline leovich
« Reply #24 on: November 23, 2024, 11:56:03 PM »
CMS only carry the plastic connector but not the terminals
