Author Topic: Over Charging need help :(  (Read 700 times)
Offline luckylefty
« on: November 17, 2024, 07:52:29 PM »
Hello all, my 74' CB750k is over charging up to 16-17v reading.
This is my current set up:
New stator coil + regulator rectifier from 4into1. https://4into1.com/reproduction-stator-w-regualtor-rectifier-lithium-lead-acid-honda-cb750k-cb750f-1969-1978/
Installed new harness
new handlebar switches
new key ignition
new fuze box(blade type)
New dynatek
My mechanic tried using stock regulator and rectifier but the reading is still overcharging.
Could someone kindly help pleaseeee :(
thank you so much.
Re: Over Charging need help :(
« Reply #1 on: November 17, 2024, 08:14:31 PM »
For starters, disconnect the white field wire from the regulator. Is the charging voltage still too high?
« Reply #2 on: November 18, 2024, 04:44:28 AM »
Bad ground somewhere or bad regulator
Offline madsundaysurvivor
« Reply #3 on: November 19, 2024, 07:50:07 AM »
Without knowing the connections of your motorcycle to the battery... forget about the rectifier and measure the output of the regulator, if it allows 17 volts to pass at more than approximately 3000 rpm it is not correct, broken or wrong conexion. Since these motorcycles do not have security systems, they will end up damaging the battery, ignition...
Offline Bodi
« Reply #4 on: November 19, 2024, 11:19:56 AM »
Often this is caused by the regulator getting a low voltage on its sense wire. That's normally the black wire. Voltage drop in the electrical system from the battery to the regulator means the regulator is trying to get its sense voltage up to (guessing) 14v. If you have 2V of drop between battery and regulator it will be trying to charge the battery to 16v.
I have installed a small relay to connect the regulator directly to battery + with key on, powering the coil from the black wire, when there's a large voltage drop and resolving that is not successful.
But with a new harness that's not so likely as it is usually from corroded bullet connectors.
Also confirm your ground is really ground, measure from frame to regulator ground. A bad ground affects charging, raised voltage on the ground works the same way as a drop in plus.
Could still be a bad regulator of course... test, if you are getting 17V at the regulator black, if it's still powering the field coil. It shouldn't be.
Offline maxheadflow
« Reply #5 on: November 19, 2024, 06:37:25 PM »
How does it do if the headlight is on? IIRC, you can still shut the headlight off a 74.
