Author Topic: M6 thread repair tips?  (Read 1030 times)
« on: November 22, 2024, 07:08:09 AM »
 I have a head or two that are pretty nice except the M6 threads are pulled. What are the best repair options for helicoil, timesert, big sert? How deep do the threads need to go?
Offline Pbeattie89
Re: M6 thread repair tips?
« Reply #1 on: November 22, 2024, 07:18:59 AM »
I've used helicoils with good results. I would get a 1.5d  kit(the length of the insert is 1.5 times the width of fastener). I am no expert by any means, but cycleX advertises using helicoils in their cylinder blocks. They should be plenty strong enough to use in the head.
Sent from my SM-G991W using Tapatalk
Offline willbird
« Reply #2 on: November 22, 2024, 08:41:20 AM »
The non branded terminology for heli-coil is "STI".....using that term to search might give you more results.
I would think 2x diameter would be plenty but I might get some 1x coils to have on hand too.
Bill
Offline CycleRanger
  • No comment about being an
« Reply #3 on: November 22, 2024, 09:22:23 AM »
For a low-torque M6 a helicoil should be sufficient.
I had to helicoil one of the studs on one of my XS650 tappet covers a while back.
Because it was very stripped I chose to drill it out to M7 and used a M7 helicoil then installed a M7-M6 step-stud. It worked very well.
« Reply #4 on: November 22, 2024, 10:42:05 AM »
Keenserts or timeserts are better but need more metal arround the hole
« Reply #5 on: November 22, 2024, 01:24:45 PM »
 I have a standard M6 helicoil set but no deep ones, I now know the terminology a little better and to look for 1.5x or 2x. and STI.
  M7 might be OK on the ones that haven't already been fixed by a ham-handed sasquatch. L0L! When I saw 5/16" in my early diecast (pre-23,000)? head I didn't want to believe it. Even under the nickel washers, although the Allen heads did work out there.
« Last Edit: November 22, 2024, 01:28:48 PM by Don R »
Offline Kelly E
  • Geriatric Hooligan
« Reply #6 on: November 22, 2024, 01:33:38 PM »
M7 might be OK on the ones that haven't already been fixed by a ham-handed sasquatch. L0L! I did 1/4" x 28 once and still regret it.
Our 80' GS 1100E four 5/16"x18 helicoils on cylinders 2 and 3 exhaust. We tried to find 5/16" to 8mm conversion studs but no luck. It was barely okay work so we chose to not mess with them.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #7 on: November 22, 2024, 03:48:31 PM »
 I ordered a set of stainless M6 in several lengths.
« Reply #8 on: November 22, 2024, 07:22:58 PM »
I use the SS threaded inserts, matching the lengths as closely as possible with the standard lengths of the inserts.
In the case of those 4 long bolts that hold the cam bearing towers in place: before the K3, most of the heads had as few as 3 threads (max 5) in those holes. I use full 1/2" (12mm) length versions in those holes - which Honda threaded to full depth starting in the K3 for sure, and some of the K2.
Offline madsundaysurvivor
« Reply #9 on: November 23, 2024, 03:27:25 AM »
If you don't want to go crazy in the future, I would use Helicoil M6 where there is space.
 If you finally tap to a larger size and use stainless steel screws on cases aluminium, be sure to use copper gauze, otherwise, over the years, galvanic corrosion due to the difference in materials may cause you to lose the thread when removing them.
« Reply #10 on: November 24, 2024, 06:43:27 AM »
I prefer Time-serts, especially for cam towers. The 4 studs + corresponding bolts + the 4 center for longer bolts.
The longer bolts sit where there are more meat in head so the thicker self threading inserts can be used.
**** Note! ****
Be aware of not drilling too deep in the 4 center thread holes for cam holders. Easy to drill thru  and get oil leak. My K2 head I link to below had  holes thru by its earlier owner(s).
I created new bottoms with JB Weld just before thread inserts went in.
Checked depths OK with cam tower tightened with its longer bolts without hitting the new bottoms. Not fun to find out too late when head is finally tightened on engine.
I have had several helicoils that went bad. The bottom part that should be broken when the coil is driven where to sit did not go off completely. Made life for bolt very bad. That with the original heli coils. The cheap copies worked better.
For covers, time serts, the softer black ones. Easy to grind off flush if it has a stick out.
Time sert kits cost some.
I have for M6. Even a big sert M6 kit for next size when even the std Time sert has gone.
I replaced some bad helicoils with time-serts. Drag out the coils and could mount the time-sert direct. Same thread. I glued the inserts with Loctite 272.
I got a sudden bad M8 for exhaust stud. Did not bother with an expensive Time-sert kit. Bought a cheap helicoil type of kit.
A head thread repairs.http://forums.sohc4.net/index.php/topic,180088.msg2088008.html
I later used that head on my K6 for a while. It is now on the shelf as a spare.
It had been ported by an amateur many years ago. Probably for +900cc.
I got it cheap. My local shop updated the port jobs and opened it up for 34mm in valves.
It got the chambers fixed too + decking it to shrink chamber diameters and volumes.
http://forums.sohc4.net/index.php/topic,184356.msg2134543.html#msg2134543
One thing leads to another! ;D
« Last Edit: November 24, 2024, 07:39:24 AM by PeWe »
« Reply #11 on: November 24, 2024, 10:53:24 AM »
Helicoils work well if you do a couple of things. As Per said measure depth prior to drill....I use the depth gauge on the Vernier calipers. Invest in a 6mm STI bottom tap. Use the tapered tap first then follow it up with the bottom tap....it prevents the insert binding in the hole. Use threadlocker on the insert and put a small chamfer on the drilled out hole....the insert screws in much easier with the chamfer. Also....use the longest Helicoil you can get in there....in general I use a 12mm length.
« Last Edit: November 24, 2024, 10:58:30 AM by MRieck »
« Reply #12 on: November 24, 2024, 06:26:54 PM »
+1
On all of these!
I've been using the clone versions of the M6 insert lately because their tang (on the bottom) breaks off easier than Helicoil's own. That's good and bad: good if you follow Mike's tips, bad if you don't bottom-tap the hole. Having a small, flat-bladed screwdriver with magnet on the shank will help to fish out the leftover piece. When they are 'stainless steel' inserts (which I favor) it is almost always type 18-8, so it will come to a magnet.
« Reply #13 on: November 24, 2024, 07:20:10 PM »
  I got a set of 100 with 5 lengths from 1xDia to 3xDia so I assume that's 20 of the 18mm deep ones. They are the stainless-steel ones.
   On the early head and cylinder, I'm going to leave the 4 holes under the nickel washers 5/16" and just use the Allen head bolts that were there. The oversize holes under the cam towers get bushings that I bought already. The cam towers will get epoxy and tube sleeves.
  The tips here will come in handy, I'll check to see if the PO drilled through the head and if so, I'll epoxy the bottoms.
  I have a couple otherwise unmolested heads that the threads felt soft when torquing so I stopped there, they get the m6 coils.
  Thanks for your expert input, should save me learning a couple things the hard way.
« Last Edit: November 24, 2024, 07:40:55 PM by Don R »
Offline rotortiller
« Reply #14 on: November 25, 2024, 04:16:41 AM »
I use SS heli-coils or variant and I try to employ the longer ones to take the bolts full thread length as much as possible in high stress applications like cam towers with high lift cams/strong valve springs. That will give the strongest attachment, and much stronger than timeserts etc. ,  that has been structurally tested and proven.  A couple of interesting videos, but as they say with the horse and water lol.
Offline 69cb750
« Reply #15 on: November 25, 2024, 04:49:28 AM »
Another video ...
8mm bolt
EZ LOK $60 712ip
HHIP $20 528ip
Time Sert $100 508ip
Heli coil $25 473ip
Aluminum threads 326ip
« Reply #16 on: November 25, 2024, 07:35:17 AM »
Glue the coil will definitely help.
Let it cure well before the bolt goes in.
I like the Time-sert where the bolts will be removed and fastened many times.
Or thin goods. I believe a glued insert will  work better then.
M6 is max 9Nm maybe 10Nm with a long thread .
Time sert kits are very expensive. A cheap helicoil type set is a must have anyway. I have both M6 and M8.
« Last Edit: November 25, 2024, 12:26:55 PM by PeWe »
« Reply #17 on: November 25, 2024, 05:23:55 PM »
Yes...watch the torque and don't discount your mechanical feel. Honda torque valves are too high. A 12mm helical will yield max torque. As Don said.... 12mm Helicoils etc have maximum thread grab...that's what you want....you will break a bolt before pulling that insert out.
« Last Edit: November 25, 2024, 05:26:00 PM by MRieck »
Offline willbird
« Reply #18 on: November 26, 2024, 04:50:26 AM »
I have always heard 1 dia thread engagement is actually enough in steel, when this thread (lol) came up it made me wonder about aluminum. One past job we machined a part that was the tie down point on an AM General Hummer, the fixtures got worked had and were put away wet. Some of the 1/2-13 holes in steel would wear out from a clamp that was tightened using those threads. So I would heli-coil them. That worked so well that for high volume stuff I started to heli coil them from day one. Usually if it got work you could just grab the coil and pull it out unwinding it in the process and run a new coil in and the fixture was quickly good to go again.
One thing a STI does is provide a smoother thread surface, makes me ponder about actual bolt stretch for a given torque. Typically that does not matter much because bolts are often far stronger than people give them credit for. We use minimum grade 5 at work for everything. I recently bought some 12' (yea 12 FEET) 1/2-13 threaded rods for a wire basket tray and I can tell you that the Sawzall knows the difference between grade 5 and normal hardware store grade 2 threaded rod :-).
Bill
« Reply #19 on: November 26, 2024, 06:36:02 AM »
Same thread depth as diameter on bolt have I heard too.Nuts have that thickness.
Aluminium need often double.
There is a very special sharp smell when removing a bolt from destroyed aluminium threads.
See a leaking valve cover, tighten it a little more and find bolt rotate is not fun.  Back in the days many bolts got teflon tape (sealing tape ) and in again. Cam chain tensioner, valve cover....
Maybe possible to add a few mm longer M6 bolt to avoid pulling the engine with all extra job... If frame kit is not used.
I have done quick fixes with longer bolts. Checked the depth first. Easy to go thru on some.
« Last Edit: November 26, 2024, 06:42:20 AM by PeWe »
Offline willbird
« Reply #20 on: November 26, 2024, 06:50:54 AM »
I need to dig around and find the engagement length for other materials and load it into my brain :-). Years ago at one job we machined the main gun elevating cylinders for M1 Abrahms tanks, it was another part for AM general. One foreman got rambunctious and bought and setup an air powered thread tapping machine so the operator could tap the threads in one part while the cnc machine worked on the next part, this saved the tapping cycle time. Well he did not bolt the parts down and his tapper holes were all at an angle to the surface / \ \ / / ...kinda like this. We had to seek approval probably from US.GOV.ORG at the top to bore them out square to the surface and install helicoils. AM General did a pull test on one repair part and it ended up stronger than a mere drilled and tapped hole.
« Reply #21 on: November 26, 2024, 06:58:40 PM »
A 'curio' to know about the long 6mm bolts that hold the cam towers down: those bolts are intended to only hold the free-spinning rocker shafts in place. They were only torqued to 70 in-lbs maximum in the early engines (before they got full-length threads) while the cam bearing caps were at 90 in-lbs. But, even at the 70 in-lbs on those longer (rocker-shaft) bolts, they often pulled the threads if the cam bearing got removed for any reason (and that happened to a LOT of sandcast engines, and many K0 as well), so those are often recoiled.
When I rebuild a K1 or earlier head I almost always install new threads in those 4 holes.
« Reply #22 on: November 27, 2024, 08:06:05 PM »
90 in-lbs is 10.169Nm which is rather much for those alu threads.
I have ruined many CB750 threads by 10Nm.
The threads need to be deep like the 4 clutch M6 which I started to tighten only 9Nm (80 in-lbs).
Max torque for M6 grade 8.8 bolts is under 10 Nm which made me to wonder about the alu threads.
