While waiting for brake parts to arrive we started fiddling with the bike. A little harder to start up this time but finally started up. Idling a little low and kept stalling out so we increased the idle to around 2,000.
Each bike is slightly different but here is my starting procedure for a cold start:
- Turn on ignition and fuel petcock
- Put choke on full position
- Hit start button with no throttle until she fires [or 5 sec], then give gas and reduce choke to half.
As far as idle, 2000 is too high, be sure to adjust it when engine is fully warmed up. I like it around 1500.
This is not a modern vehicle with fuel injection, expect to use the throttle for at least a minute to keep it running when start it cold. When starting it warm, it should fire immediately and settle to a nice even idle or it needs to be tuned.
I can sense your passion for the old girl, isn't it great!
