Author Topic: Riken Honda piston rings question  (Read 718 times)
Offline slyguy
« on: December 10, 2024, 03:52:58 PM »
New yamiya Honda Riken Std rings, top 2 are identical with no bevel. Just put letter R facing up? I’m at .008 ring gap:)
Re: Riken Honda piston rings question
« Reply #1 on: December 10, 2024, 04:54:28 PM »
One of the rings should have a greyish outer face on it, which is the top ring. While you can't see it easily, the 2nd ring has a 3-degree bevel on the bottom of the inside edge - at least, that's what the Riken .025mm rings I used 2 months ago looked like. They weren't from Yamiya, though.
Offline slyguy
« Reply #2 on: December 11, 2024, 09:15:07 AM »
On mine the gray rings have the bevel & letter R on the same side but I’ve read bevel down & letter up which is more confusing? Btw pic is a ring which got broken but new one on the way!
« Reply #3 on: December 11, 2024, 10:41:47 AM »
The letters go to the top, always.
« Reply #4 on: December 11, 2024, 11:07:21 AM »
I always took that grey to be chromed edge so top ring
Offline slyguy
« Reply #5 on: December 12, 2024, 03:38:40 PM »
Thanks guy for the clarification 👍
« Reply #6 on: December 25, 2024, 03:22:34 PM »
  I was once told if the rings come packaged together, they will be in their correct order and direction, top to bottom. Has anyone else heard of this?
« Reply #7 on: December 27, 2024, 04:14:27 PM »
I've seen them that way, and also not that way. I guess I'd vote to not count on it?
