I hope the 71.25mm rings will get a long life then
File the inner ends (rounded) of the oil rails helps the thin oil rails to not hook into the expander ring during assembly as I did.
-bigutah: Which bire size do you have?
I guess my billet block will run long enough with 71.25 mm pistons. Possible to bore for 72mm and new nikasil. A little bit complicated to find where except Millenium.
I did an oil change today thanks to bigutah's comment about TMR and 4-1 sound.
Warm-up afterwards. Video when warm and idling evenly.
Acc pump might need to be reduced. It smoke a little when giving heavy throttle. But might be as how it works.
I have seen the long squirts when carbs were off. I can reduce the stroke by a small screw beside idle screw, was 6 turns out, turned in 2 turns after video.
https://youtube.com/shorts/IWY3EY26LnY?si=z4ON52fnKENu6MQ-My TMR's had strange needles. The model for a bigger model. Maybe out of stock when built?
I have a pile of junk beside bike that I'll take to a recycling station. I stretched my back a month ago that reduced my abilities. Coming back into action.
Page below need to be scrolled down. Sometimes really slow
Carburetor Setting Method by YOSHIMURA
TMR-MJN/TMR/TDMR Carburetor Setting Parts
https://www.webike.ph/ph_news/webike-original/columns/20201229-carburetor-setting-method-by-yoshimura/
