Author Topic: JMR billet block build with RSC 970 transmission  (Read 19978 times)
Offline bigutah
Re: JMR billet block build with RSC 970 transmission
« Reply #50 on: January 07, 2025, 10:54:10 PM »
Tonight’s update -
Beringer Dual Piston calipers with Mark Zero Rotors from the early 70’s installed, Genuine RSC Team honda spare oil tank with RSC CR750 kit oil cooler and lines installed. Have the moto GP on for now until I get my RSC genuine CR750 works 4-4 pipes back from repair.
« Reply #51 on: January 08, 2025, 04:36:15 AM »
I do like the RSC cooler and lines with the big oil tank. Much better than the aftermarket coolers that went down the front to the filter.
Coming along nicely.
Online PeWe
« Reply #52 on: January 08, 2025, 12:14:55 PM »
Beringer brakes will stop quickly. I have looked at their website. But no caliper mounts for K6 fork.
Top notch brakes what I have understood.
Offline bigutah
« Reply #53 on: January 08, 2025, 01:14:45 PM »
2 left pipes repaired nicely, Just needs some paint. They are on the way home. should sound pretty wicked.
« Reply #54 on: January 08, 2025, 01:44:41 PM »
Is that caliper spacing the same as the 77/78 F2 which is also the same for the 79/80 CBX and DOHC? I think 45 degree banjos on the calipers would be better. ;)
Offline bigutah
« Reply #55 on: January 18, 2025, 02:30:57 PM »
Not much accomplished this weekend. But the pipes are 75% done.
Offline bigutah
« Reply #56 on: February 17, 2025, 10:01:23 PM »
Magnesium replica rear hub wheel build to WM5 rim.
2/17/2025
Man, boranni welds are trash.
« Reply #57 on: February 18, 2025, 01:36:47 AM »
Nice bike porn...
« Reply #58 on: February 18, 2025, 07:35:58 AM »
Looks good. I'm a big Sun rim fan.
« Reply #59 on: February 18, 2025, 10:43:55 AM »
Not to be confused with the Chinese Rising Sun rims from 4into1.co m
« Reply #60 on: February 18, 2025, 01:13:34 PM »
Riding home on bicycle several decades back I turned a rear wheel into a potato chip looking item after hitting big stones in bike lane curbing area in a pull out from a restaurant. It was at night and street lights were not illuminating that area. Rock caused broken spoke and that caused blowout and more spokes to break. I was lucky enough to have good balance and didn’t go down. Had to walk bike to corner about 3/8 mile away to catch last north bound bus a couple miles north before getting off and walking bike home about a mile and half West to my apartment.  I replaced it with heavy duty Sun rim and had local bike shop rebuild wheel with heavier spokes. I too like Sun Rims…
Offline bigutah
« Reply #61 on: February 25, 2025, 03:14:37 PM »
Collecting more junk…..go figure
« Reply #62 on: February 25, 2025, 05:59:02 PM »
Twin sisters are always exciting…😜
Offline bigutah
« Reply #63 on: February 26, 2025, 11:15:13 PM »
K swing arm d
K swing arm bolted up. Nice looking wheel for short.
Needs Titanium Axles now.
Motor is about done and on its way back from Ken.
I let Ken assemble this round, I’m a great wheel lacer and Machinest, but f*ck XA ring packs on your 2nd go ever. 72mm bore with 1.5 thou cylinder to wall clearance. 11.5-1 compression, should be a fun toy.
Cut down some oak today, thought of you Mike. heavy ass #$%*.
Online PeWe
« Reply #64 on: February 27, 2025, 03:17:37 AM »
The bike looks good! ;D
The thin oil rings could hook into the expander and do not compress completely. That's how I pinched one.
Next try,  all oil rings got the inner end corners filed to a smooth rounded corner.
I did that later with the 970cc kit too, despite the thicker XC rings.
The new Wiseco rings had harsh burrs on he ends. Important to smooth them off with 240 or 400 grit paper before testing in bores.
« Reply #65 on: February 27, 2025, 07:08:24 AM »
K swing arm d
Yeah....I have a big pile to tend to when it gets warmer.....cutting to length and splitting. It's all worth it when it is 5F outside with a 20 to 25 mph wind and the living area with the wood stove is 75F.  ;)
 72mm with 11:5 CR will be a blast....literally. Great torque.
 Per is absolutely correct about paying attention to the ring ends especially the oil rails and expander ring.
« Reply #66 on: February 27, 2025, 07:10:40 AM »
BTW....the back end of the bike looks great....something about a large drum brake setup....it just looks tough and all business. ;D
Online PeWe
« Reply #67 on: February 27, 2025, 09:03:20 AM »
That really good looking wheel in a K swing sends want that vibes!
I have to polish my wheels and try to forget.... ;D
Offline bigutah
« Reply #68 on: March 18, 2025, 11:41:42 AM »
The most recent FB marketplace score. Obviously display purposes only. But still neat!
« Reply #69 on: March 18, 2025, 08:43:58 PM »
Are they date coded?   I would have to have them too.  Look so cool and what a rare find.
Offline bigutah
« Reply #70 on: March 27, 2025, 07:26:09 PM »
Cycle X built the beast after I discovered how much I hate XA ring packs on 72mm pistons through trial and ultimately error and a few scratches, One more step to completion.
Huge shout out to Ken for his massive amount of effort in the situation. Millennium didn’t do a good enough job on the replating process the 1st go around, but they came through with good results the 2nd try.
Ken taught me this.
 test a mechanics/machinest ability and challenge them to do the job to perfection and be a absolute pain in the ass in the process and hold them accountable to that standard, and you will wind up with stellar results in the end.
This has been a cool experience and challenge thus far. To be continued….
Offline bigutah
« Reply #71 on: March 27, 2025, 09:10:30 PM »
On another note. Found a genuine RSC CR750 tank. Talk about a gem. Brand new in the box too!
« Reply #72 on: March 28, 2025, 04:15:54 AM »
WOW! Cool find!
« Reply #73 on: March 28, 2025, 05:53:15 AM »
I know where that came from. ;)
Offline bigutah
« Reply #74 on: April 01, 2025, 11:10:02 PM »
Stellar job by Ken. Will post a Dyno video soon in the chassis with TMR carbs and HRC 4-4 Daytona exhaust
