Author Topic: Air screw to reduce decel popping?  (Read 3800 times)
Rayzerman and 1 Guest are viewing this topic.
Re: Air screw to reduce decel popping?
« Reply #75 on: January 30, 2025, 12:55:23 AM »
I had issue with fuel hoses that were slightly kinked. It caused fuel starvation in higher speeds.
Where the fuel connection is, in wrong angle.
Yep, it is often overlooked. I have seen it more than once when softer aftermarket tubes were used. Best advice I can give: have tubes at the original length and diameter.
I've distilled the correct dimensions of my CB500 tubes, knowing: 17 and 28 cm resp., in the apropiate parts list: https://www.honda4fun.com/dwnload/Part-List/CB500/CB500-K2-76-Parts-List.pdf On p.32 #15 and #16 we have partnumbers: 95001-55170-040 and 95001-55280-040.
On previous CB500 models which had the bowltype petcock, partnumbers were: 95001-55180-040 and 95001-552300-040. I don't know if Honda has applied this way of numbering for tubes on other models though.
Adding inline fuelfilters in CB500/550 tubes brings a risk.
Offline Bigmant
« Reply #76 on: January 30, 2025, 06:40:55 AM »
Just checked! Lines are not kinked any where and they are all genuine Honda replacements.
‘73 CB750 K3 Owned by my father and now me
Build post: http://forums.sohc4.net/index.php/topic,190516.msg2216419.html#msg2216419
« Reply #77 on: January 30, 2025, 07:10:49 AM »
Which model of carbs? Stamped on carbs.
- Is it really stock needles?
- Not cheap not usable aftermarket that look totally different in both lenght and taper?  If thicker, it will run leaner.
My 086A carbs (stock K6)
Had needles at 4th notch from top with 836, 4-1 and pods
Those carbs later on my K2
Same needle setting to run well. Tried middle first.
Changed to 064A carbs where 4th notch was too rich. Middle (3rd) a must. (These carbs have different needle taper/thickness)
Air screws 1 turn out.
Offline Bigmant
« Reply #78 on: February 01, 2025, 08:18:24 AM »
Does anyone know why there might be two small holes in the roof of the float bowl in one carb and only one in the other? And could this be part of my problem? It makes me think the carbs might be different…
The carbs are stamped behind the backing plate which I don’t want to take off, before someone asks hahaha
« Reply #79 on: February 01, 2025, 09:42:00 AM »
Carb model stamped like these photos
086A
064A
Other versions
7A, 657A
« Last Edit: February 01, 2025, 09:49:13 AM by PeWe »
Online newday777
« Reply #80 on: February 01, 2025, 10:51:20 AM »
To share the bowl vent with the outside carb bowl.
You have 2 vent hoses, both hooked to the 2 and 3 carbs, because of the slide going down through the center blocking a pathway to go straight across the body, so they just add the second bowl vent hole in the 2/3 carbs, it's the pathway to the outside 1/4 carbs.
Offline Bigmant
« Reply #81 on: February 01, 2025, 01:10:18 PM »
Got it! So totally normal then!
Offline Bigmant
« Reply #82 on: February 08, 2025, 03:12:56 PM »
Ok I’m back to the drawing board everyone. I need some more help.
I cannot possibly think of what could be wrong with the bike. My next step is to pull the carbs again and go back to 140s on the mains.
The bike stumbles in first gear and dies with any amount of throttle.
There are no air leaks or exhaust leaks. The fuel lines are routed properly through the holes in the carb rack and down into the nipples, with no kinks in the lines. Floats are calibrated to exactly 26mm.
Currently running
130 mains
40 idle
1.5 turns out for air screw.
Pods
4 -1 exhaust
It could be something simple, but I’m at my wits end as to why the bike has no power with this large of a main jet.
« Reply #83 on: February 08, 2025, 04:03:29 PM »
The larger measured distance meant a lower fuel level in the float bowls, causing a leaner condition, and may have explained the large main jets? I asked on the other thread in 2022 if you had performed a "clear tube" test to check the actual fuel level in the bowls, and I would recommend doing it now. Do check the spark plugs: if they are black and sooty or black and wet, the current setup is too rich.
« Reply #84 on: February 08, 2025, 04:07:23 PM »
lets see your plugs
Offline Bigmant
« Reply #85 on: February 08, 2025, 05:30:02 PM »
lets see your plugs
Are we implying that I pull the plugs even when the bike won’t run in first gear? Not sure what the plugs will say when there is a more obvious issue.
Offline Bigmant
« Reply #86 on: February 08, 2025, 05:31:17 PM »
Scottly, are we implying that the float bowl level could be the cause of no power in first gear?
« Reply #87 on: February 08, 2025, 05:37:21 PM »
lets see your plugs
the plugs are not the issue...but looking at them will tell you what your issue is.
« Last Edit: February 08, 2025, 05:42:10 PM by scottly »
« Reply #88 on: February 08, 2025, 05:38:47 PM »
The spark plugs show what is actually happening in the combustion chambers, and are the first things to check when trouble shooting.
