« Reply #1 on: January 17, 2025, 06:41:50 AM »
Ned
There are 2 ways, both require some drilling.
1. Get a reverse drill bit a little bigger than the hole in the jet so it can bite into the brass.
Heat the carb body around the jet to melt the gummed old gas that has locked the threads(the reason it snapped off!). You should see the gummed gas bubble.
Go at a slow speed when drilling so it can grab as it gets in the brass.
2. Drill out for an easy out of the correct size.
Sorry, no easy way so you don't have to drill.
Logged
Stu
My current rides
Prior bikes....
