Author Topic: Tank rust removal.  (Read 1886 times)
Online Ozzybud
  • Honda Lover
  • Honda Lover
Tank rust removal.
« on: January 17, 2025, 03:19:53 PM »
Good news turned to bad news after treating the CB350F tank with Evapo-Rust. I have included a before and after photo of the inside. I was amazed how clean it got the tank with only soaking  for 3 days.
Then I noticed on the forward edge there was 3 small blisters in the paint. Definitely pin holes coming from the inside out. The outside of the tank is almost flawless with the original paint.
I have some epoxy tank sealer in route. I am hoping to get it sealed up so I can ride it this summer. Does this type of sealer work? I am on the hunt for a decent tank that I can re-paint. Most of the ones on Ebay look worse inside  than mine.
Hopefully the sealer will work for the short term.
« Last Edit: January 17, 2025, 03:27:21 PM by Ozzybud »
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline Flyin900
Re: Tank rust removal.
« Reply #1 on: January 17, 2025, 03:32:06 PM »
I use Tech Steel as a great flexible sealer that becomes as solid as steel once set. It can be sanded, filed and worked once it has set hard. It is impervious to gasoline or any diesel etc. I would think that JB Weld makes something close to this. It is a metal epoxy that is workable initially. In the case of Tech Steel it is rock solid in 15 minutes with  a full cure in 1 hr. JB Weld not so much with the quick set up times.
You should be able to use it long term as a pinhole sealant that will not deteriorate with time since I have used it for over a dozen years. I have even rebuilt broken fins on a cylinder or head with a thin wire scaffolding to support the new fin area. It has lasted for years in that set up too.
« Last Edit: January 17, 2025, 03:33:49 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Online Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #2 on: January 17, 2025, 04:02:08 PM »
I am a little hesitant to strip and re finish this tank. I am assuming that the metal is paper thin and with 3 showing now 30 more pinholes are ready to pop through.
I bought some inside of the tank coating (Caswell Epoxy). I am hoping That will seal it up.
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #3 on: January 17, 2025, 04:15:05 PM »
Brickhouse Builds on YouTube just did a video on Caswell coating a tank.
Online Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #4 on: January 17, 2025, 04:35:35 PM »
Thank you... great video!
Looks like i bought the right product!
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline beemerbum
« Reply #5 on: January 17, 2025, 04:37:20 PM »
How much Evaporust did you put in the tank?
Online Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #6 on: January 17, 2025, 04:41:36 PM »
100 percent full 3+gallons
100 percent full 3+ gallons.
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #7 on: January 17, 2025, 05:05:02 PM »
You are welcome. I just saw it last night.
Offline Flyin900
« Reply #8 on: January 17, 2025, 06:14:54 PM »
[/quote]
The Caswells makes better sense for the pin holes in the upper area of your tank. I suspected it was the seam or bottom area of the tank where they are mostly evident on many tanks.
FYI on the Caswells I found it a very thick consistency and poorly coating of the entire tank area easily when the tank was rolled around. I recommend using a thinner as noted in the instructions to thin and allow the material to flow around the interior of the tank easier. Acetone works very well as the thinner for this purpose.
« Last Edit: January 17, 2025, 06:21:40 PM by Flyin900 »
« Reply #9 on: January 17, 2025, 09:21:25 PM »
+1 on thinning it...I used it once an did not and it was very difficult to get it everywhere inside.  If you don't get full coverage the gas can get underneath and ruin the lining
Offline Kelly E
  • Geriatric Hooligan
« Reply #10 on: January 18, 2025, 10:57:53 AM »
I have heard many good things about POR-15 tank sealer. It comes with the needed prep cleaners for proper adhesion.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline jaytee-nz
« Reply #11 on: January 18, 2025, 02:53:49 PM »
I've used POR15 many times and it works really well - BUT you must follow their instructions to the letter, especially about the tank being 100% dry before putting the lining product in. It's easy to think it is dry after a few hours but if you check the inside seams, they hold moisture and it takes many, many hours of blowing a heat gun in there to completely dry it out.
Offline CycleRanger
  • No comment about being an
« Reply #12 on: January 18, 2025, 03:04:34 PM »
Same, I've used it twice. Good results.
Online Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #13 on: January 18, 2025, 03:26:22 PM »
I am going to use the Caswell system as i have it in my possession. i flushed it thoroughly 3 days ago 3 times with Acetone going to wait a few more until i do the application... keeping my shop 75-80° in preparation.
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #14 on: January 18, 2025, 07:08:29 PM »
The seams are critical to be dry before you seal up the tank no matter what liner you use. Trapping moisture leads to very bad results when that moisture causes rust and seal failure.
The POR product reacts with water flash curing and that is a week currently, it doesn't combine with all the water, leading to seam failure...
So, warm that tank up plenty to drive out the moisture in your prep.
Caswell is a good product, as is the POR...
« Reply #15 on: January 19, 2025, 08:35:18 AM »
 I did a Fibermold tank with Caswell, it is an old custom fiberglass tank. It holds 3 gallons tank and I had the large kit, so I mixed half of it. I could actually see the product flow through the bottom of the gel fiberglass and knew it was too thick so I mixed the second half of the kit and dumped it all in, thinned a little. I was able to get awesome coverage.
 Caswell is also able to protect the old fiberglass from alcohol.
« Reply #16 on: January 19, 2025, 01:51:56 PM »
I also have one of those tanks and another much larger Reed  Titan tank that both need lining.  How much have you actually used your Fibremold tank, Don?
Online Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #17 on: January 22, 2025, 04:41:31 PM »
Got the tank sealed this morning with the Caswell Clear Epoxy liner. Went very well. Rolled the tank around for 25 minutes.
Rebuilt Kehin petcock and new repo cap
I'll give it a few days before adding gas.
I have high hopes!
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #18 on: January 23, 2025, 07:19:39 AM »
Keihin makes petcocks?
Online Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #19 on: January 23, 2025, 09:58:25 AM »
I rebuilt  mine. The original is made by Keihin.  At least it has a huge "K" like the jets on the strainer cap
« Last Edit: January 23, 2025, 11:57:28 AM by Ozzybud »
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline Cevan
« Reply #20 on: January 23, 2025, 10:19:32 AM »
Ozzy, how did you keep the sealant from getting in the threads in petcock area?  I'm referring to the 2 M6 screws that secure the petcock to the tank.
1972 CB500/4
1974 CT70
Online Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #21 on: January 23, 2025, 11:08:17 AM »
7
I used 2 bolts that just protruded the same length as the factory screws, I coated them with a touch of wax.i used a simple rubber plug to plug the center hole.
I then drained the majority of the excess which was only a couple ounces at the 35 minute mark from the filler i then pulled the rubber plug and drained the rest from the bottom.
At about 3 hours I removed the screws and used a small file to open up the center hole to the factory size.leaving a little bit of the coating around the edges.
« Last Edit: January 23, 2025, 11:36:29 AM by Ozzybud »
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Online Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #22 on: January 23, 2025, 01:01:44 PM »
I thought Keihin manufactured all the petcocks?  Most do not have enough real estate to display their Logo.
The same logo is on my other bikes with  Strainers!
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline Flyin900
« Reply #23 on: January 23, 2025, 02:09:38 PM »
I have high hopes!
Did you have to thin the material, or was it more runny as received??
Online Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #24 on: January 23, 2025, 02:54:47 PM »
I have high hopes!
It was the thick type!  I used 1oz of thinner. It was still very thick but i didn't want it to be runny. It moved around in the tank just fine. 100 percent coverage was accomplished for sure!  I had my shop and the product at 80 degrees.
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
