Author Topic: Cb750 K1 Seat Adjustment?  (Read 759 times)
Offline TideWater2
« on: January 25, 2025, 08:40:11 AM »
I have swapped a couple seats back and forth and it is not working to well. Is there any adjustment in these? They are all Honda seats. The main problem is the latch is traveling to far down to work properly and the seat is low on the left side, all cockeyed. The latch won't release without pulling up hard on the seat, it pops up to the latch, then you can release the latch. It look like I need to add to the rubber mounts, but I have never seen anyone doing this or talking about it, I must be missing something.
2 - 1971 CB750 K1s
Offline newday777
Re: Cb750 K1 Seat Adjustment?
« Reply #1 on: January 25, 2025, 09:11:02 AM »
If you don't have the rubber bumpers under the seat that is your problem.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #2 on: January 25, 2025, 09:13:02 AM »
The rubber bumpers set the height. There is no height adjustment.
No one mention it because it is a given.
Stu
My current rides
Prior bikes....
Offline TideWater2
« Reply #3 on: January 25, 2025, 09:35:21 AM »
All of the rubber bumpers are in place on all seats and look identical to each other.
2 - 1971 CB750 K1s
Offline denward17
« Reply #4 on: January 25, 2025, 09:43:03 AM »
Either the mounting points are bent or the seat pan has been twisted?
Offline Kevin D
  • SE Michigan
« Reply #5 on: January 25, 2025, 10:22:21 AM »
Got any photos?
The K1 was a 1 year only seat.
Distinguished by the piping path.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #6 on: January 25, 2025, 11:08:51 AM »
It should have these rubber bumpers.
Offline newday777
« Reply #7 on: January 25, 2025, 11:28:14 AM »
Post pictures of all your seats, top, bottom , sides and ends. Something is fishy
Stu
My current rides
Prior bikes....
« Reply #8 on: January 25, 2025, 02:41:23 PM »
 You are pinching the safety catch together aren't you, I wouldn't mention it except I observed a well-known supplier of our parts when he was unable to open the seat that he sold to me. I had to show him how to pinch the safety catch together. L0L!
« Reply #9 on: January 25, 2025, 03:06:17 PM »
The hinges have slotted bolt holes where the hinges bolt to the seat.  I have seen where if the latch does not line up just right it dpes not sit down all the way, also makes the bumpers not hit right, also the old bumpers I have seen have usually hardened into a compressed form,, so new bumpers may have to compress, also the hinge tabs on the frame bend easily so those may need to be bent nack into the correct place,,,
Offline TideWater2
« Reply #10 on: January 25, 2025, 03:36:40 PM »
Yes. I have two original seats on two K1s and the latch works as it should. When I put a NOS seat on is when I ran into the issue. The latch works fine, the fit is the problem.
2 - 1971 CB750 K1s
Offline TideWater2
« Reply #11 on: January 25, 2025, 03:38:03 PM »
I'll try to get some good photos tomorrow. Thanks
2 - 1971 CB750 K1s
Offline TideWater2
« Reply #12 on: January 25, 2025, 03:42:55 PM »
The seat is traveling down to far on the left/latch side. I will look at the hinges a little closer tomorrow when I take pics. Thanks
2 - 1971 CB750 K1s
Offline BenelliSEI
  • 1969 cb750
« Reply #13 on: January 25, 2025, 04:54:08 PM »
Check to see that all of the rubbers stops are landing squarely on the frame. The most forward pair should be shaped to land on the frame rails? This picture is an earlier KO seat, but I believe yours should look the same?
Any chance you have the hinge brackets on 180 degrees around the wrong way? I’ve done it and then all the pads miss the frame……
« Last Edit: January 25, 2025, 05:01:51 PM by BenelliSEI »
Offline TideWater2
« Reply #14 on: January 26, 2025, 12:30:18 PM »
I got some photo taken. All of the rubber bumpers measure out the same on both seats and are in the same spacing/location. I used the old latch because the new latch was way out of aliment despite looking identical by eye balling them.
2 - 1971 CB750 K1s
Offline TideWater2
« Reply #15 on: January 26, 2025, 12:43:35 PM »
There is a slight difference in the hinges, but it sure don't look like enough to cause the seat to fit so poorly. The hinges spec out the same on both seats.
2 - 1971 CB750 K1s
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #16 on: January 26, 2025, 01:17:11 PM »
Can you post a pic of the hinge mounts on the frame?
Also a pic of the seat mounted on the bike from a couple angles to show how it's not fitting.
Sounding like the mounts on the frame are bent.
Have you tried leaving the bolts on the seat mounts just barely tight so you can massage it around.
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline TideWater2
« Reply #17 on: January 26, 2025, 01:40:58 PM »
Here is photos of the mounts on the bike. I would think if they were bent, both seats would not fit. It will probably be tomorrow before I get the pics of the seat remounted.
2 - 1971 CB750 K1s
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #18 on: January 26, 2025, 03:03:54 PM »
You stated that both the seats fit poorly. That leads me to believe that its not the seats.
Someone stated earlier that your bike is a one year only for the seat. Are we sure they are correct for your bike?
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
Offline TideWater2
« Reply #19 on: January 27, 2025, 06:41:44 AM »
Ozzybud,
I wasn't very clear about the seats. The original fits fine, but fitting a NOS seat is not fitting very good. Sorry.
2 - 1971 CB750 K1s
« Reply #20 on: January 27, 2025, 07:33:15 AM »
Is the new seat an aftermarket with plastic base?
Offline TideWater2
« Reply #21 on: January 27, 2025, 07:42:26 AM »
No, it is a Honda NOS seat.
2 - 1971 CB750 K1s
Offline 69cb750
« Reply #22 on: January 27, 2025, 08:12:37 AM »
I have added washers between seat and latch to get the seat level and latch latching.
