Author Topic: Polishing or repainting engine fins?  (Read 635 times)
Offline jakeNAIL
« on: January 30, 2025, 07:41:52 PM »
Does anyone know a good way to clean up aluminum engine fins? The paint on my cb750 was chipping a there is a layer of corrosion on the fins. Would it even be an option to repaint the engine? I'm new to this sort of thing so everything is a learning experience. Thanks
Offline ianbrsn7
Re: Polishing or repainting engine fins?
« Reply #1 on: January 30, 2025, 07:46:58 PM »
I had every external piece of my engine vapor blasted by a local guy i found on facebook. You'll need to obviously take the engine apart, but it came out looking amazing. I was quoted some pretty high prices calling shops and what not (around $150/hr) but the guy i found works for about $45 an hour out of his own shop. See if you can find someone like that!
I have always been curious to if people have ever had a vapor blast then clear coated over it and the results of that after 3-5 years.
« Reply #2 on: January 30, 2025, 08:01:14 PM »
Yes repainting is an option.
Preparation is a key factor to results.
You say yours has corrosion on the fins? Pictures?
Offline jakeNAIL
« Reply #3 on: January 30, 2025, 08:18:34 PM »
Here is a picture
« Reply #4 on: January 30, 2025, 10:01:20 PM »
Get some brass brushes(non magnetic!) at the hardware store to clean up the fins. You can also use scotch Brite pads wrapped on a paint stir stick.
Offline pjlogue
« Reply #5 on: January 31, 2025, 02:56:22 AM »
Trying to polish engine fins would, I think, be a nightmare of labor.  Repainting would be preferable.  Surface prep is the key to a good job.  When I restored my 750 I used a gravity feed soda blaster I bought from Harbor freight.  Again, prep of the part is critical.  All grease and oil should be removed before blasting.  Soda blasting has a benefit over vapor blasting in that it will strip old paint quickly and leave the surface slightly rougher than vapor blasting and is a very good surface for paint to adhere.
Vapor blasting is another option.  It will leave the surface with a more sheen like look than soda blasting and can be top coated with a high temp clear coat.
If the engine is disassembled during the blasting, it is absolutly critical to have the parts cleaned and every nook, crannie and passage physically brushed out several times between rinses and high pressure air blown down each passage.  Any blind holes need to have an air tube stuck down to the bottom of the hole and then blown out.  Water will disolve the soda blasting media.  Vapor blasting uses glass beads and the glass beads have an affinity to adhear to any oil/grease so solvents should be injected down holes with brushing to chase the holes.  You do not want ANY glass beads inside the engine after reassembly!
-P.
« Reply #6 on: January 31, 2025, 06:18:50 AM »
Put bolts/screws in any threaded hole for any type of blasting. I use short Allen set screws.
