Hey, tuning up a 77 CB750A for a coworker, I dont have a manual for it, Im very familair with the 550's and Ive read plenty on the 750's but I need a couple specs.
I need the exhuast and intake tappet adjustment specs. I also need the factory mixture screw setting for the carbs(how many turns from lightly bottomed).
Is gap/dwell for the points the same as on the 550's? When I adjust the cam chain, is it the same as a 550? On the 550 you rotate the crank until the TDC for 1-4 shows up, then continue to rotate until the stud that the spring for the advancer mechanism weight attaches to is just past the timing mark, then adjust the chain since the slack will be at the back of the engine. Same thing? I know the 750 cam chain adjuster is different and tends need a little coaxing for it to adjust. Thanks!
