Author Topic: tank repair  (Read 2204 times)
Offline CBGBs
    • Ride or Rot vintage motorcycle event in FTW
tank repair
« on: March 25, 2007, 06:23:43 PM »
My tank has a crack at one of the ballance tubes. I've tried to repair it with a two part epoxy like JB Weld Quick and it didn't hold.
Is it recomended to weld this shut or should I use a fiberglass resin?
'66 CB77 Superhawk  '73 CB350G Cafe  '75 CB400F '65 S90  '78 CB750 SS
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: tank repair
« Reply #1 on: March 25, 2007, 06:52:06 PM »
"Welding" and "Gas Tank" are three words that require a whole lot of forethought.
I fixed a pinhole or two using a putty-like gas epoxy to fill the hole.  I let it cure fully and then 'paintied' over it with another gas tank fixer/sealer.  I bought both gas-tank sealers at the local Autozone/Advance auto.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: tank repair
« Reply #2 on: March 25, 2007, 07:13:39 PM »
Disclaimer:
I am not responsible if this doesn't work and blows up.
Can you fill your tank with CO, CO2 or Nitrogen?  Fill with inert gas then you should be able to weld it.
James
PS: I have tried this before myself and am 1 for 2, fixed one, blown one.
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline Peterbylt
Re: tank repair
« Reply #3 on: March 25, 2007, 08:11:11 PM »
I used a product called Marine Tex to fix my Tank ten years ago and its still holding strong.
http://www.marinetex.com/PRODUCT%20PAGE_files/All%20MarineTex%20Putty/marinetex%20prod%20info.htm
Peter
1975 550F SuperSport
1975 GL1000 Goldwing
1979 CM400A Hondamatic
1981 GL1100 Goldwing
1985 CMX250C Rebel
Offline mkramer1121
Re: tank repair
« Reply #4 on: March 25, 2007, 09:46:16 PM »
Saw something the other night on Classic Rides on the DIY network.  They were going to cut open an old Indian tank and reweld it shut.  Before they cut into the tank, the stuck the tank on the end of a car exhaust via the fuel tap and ran it there for a couple minute to brun off any excess fuel.  Then they cut into it and welded it no problems.
Added this link to the how to:
http://www.diynetwork.com/diy/ab_auto_restoration/article/0,2021,DIY_13680_5288294,00.html
« Last Edit: March 25, 2007, 09:52:30 PM by mkramer1121 »
Offline kghost
Re: tank repair
« Reply #5 on: March 25, 2007, 10:56:19 PM »
Its really very simple.
Take your garden hose and stick it in the tank.
Turn on the hose.
Leave it on for half an hr.
Gas weighs about 6 lbs per gallon
Water weighs 8 lbs per gallon.
The water will flush out any gas and fumes. I've never had one blow up using this method.
As always gas and fire don't mix and be careful.
Stranger in a strange land
Offline CBGBs
Re: tank repair
« Reply #6 on: March 26, 2007, 02:58:19 AM »
I just conditioned the inside of the tank and I plan on storing it. I don't want to fill it with water and allow rust to overtake it in storage.
This is great! I have options. Thank you.
I may try the exhaust method, or perhaps another putty. I have something like a metal putty that I've never used.
Any further suggestions would be appreciated.
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
Re: tank repair
« Reply #7 on: March 26, 2007, 04:35:22 AM »
hey there CB I would either clean up the area again and redo with J B quick OR there is a nice brand of fuel tank repair out there got mine at VIP  for ten bucks comes with sand paper little brush a piece of fiberglass cloth and the two part mix works great  I garanttee if you clean the area good enogh it will stick good luck seven fifty four ever Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline kghost
Re: tank repair
« Reply #8 on: March 26, 2007, 05:46:29 AM »
Do what ya will.
If you want a tank fixed permenantly ...weld it.
If you want a semi permenant fix...play with putty, tapes, epoxies, etc.
If your concerned about rust in the tank you can:
Dry it with a hair drier
When dry slosh MEK around in it to pick up the water
Or put a bag of desiccant in it.
Re: tank repair
« Reply #9 on: March 26, 2007, 06:38:58 AM »
You may be surprised to find out tre original material holding that tube on was solder. Soilder is a great sealer for pipe joints and attaching parts since it flows.
Offline xtalon
Re: tank repair
« Reply #10 on: March 26, 2007, 07:11:22 AM »
My buddy who owns a body shop is going to do some welding on my tank and when I asked him about it, he said we would run a hose from a engine to fill it with exhaust (carbon monoxide) and then weld it.  We haven't done it yet, so if quit posting over the next couple weeks, you'll know it didn't work.   ;)
The tank has been off the bike and empty for the last couple weeks and I have left it open to let the fumes escape, but it still smells of gas.  I'm going to seal my tank w/ POR 15 too, so before I take the tank to my buddy, I think I going to use the marine clean and hopefully it will get us much of the gas and fumes out as possible before hand.
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
Offline rhinoracer
Re: tank repair
« Reply #11 on: March 26, 2007, 08:07:59 AM »
I've done both, to weld first stick the big opening into your car's exhaust and leave running for a few minutes, the more the better. Warm the engine first so it doesn't condense into the tank. then weld as you wish. If there's rot in the tank you'll only burn a big hole into it instead of welding.
I've also plugged holes as large as a dime using bar soapm, not any kind of soap but the kind used for clotheswashing. Lasted for 4 years without leaks till I sold the car.
But if it's going to receive stress you're better off welding it, any kind of adhesive is prone to failure, just make sure you know what you're doing.
Baja native.
Offline CBGBs
Re: tank repair
« Reply #12 on: March 26, 2007, 07:00:13 PM »
Soldering or welding seems like the permanent plan, but I wonder if a radiator shop might have the ability to fix this thing. Any idea?
jsaab2748
Re: tank repair
« Reply #13 on: March 26, 2007, 08:35:35 PM »
Radiator shops commonly repair and recondition car gas tanks.  But you prob knew that eh? Might be the way to go if you know of a
reputable place and don't feel like messing with it.
Offline cafe75-550
Re: tank repair
« Reply #14 on: March 26, 2007, 09:41:27 PM »
I take my tanks to a radiator shop and have them "boiled out".The chemical process removes just about everything in the tank. Its really the only way to guarantee that there aren't any residual fumes/residues in the tank (Carbon monoxide itself is a flammable gas, with an ignition temperature of 1,128 degrees F). I usually braze the tanks instead of welding, lower temps mean less distortion and the filler metal flows into any gaps/imperfections that welding can sometimes leave.
New bike!
'07 Triumph Speed Triple 1050
Never enough projects!
'75 CB550 "Cafe", '76 CB550 parts bike
'64 Norton Atlas featherbed/'71 Triumph 750 Triple (Triton project)
'68 BSA Thunderbolt (frame and cases, project in the wings)
'57 Triumph Thunderbird (frame and mostly complete engine)
Re: tank repair
« Reply #15 on: March 26, 2007, 11:34:51 PM »
Brazing will give all the strength you need and you will neither melt nor lose any parent metal in the process.  Seems perfect for this kind of repair.  I used water to flush the tank when I repaired pinholes in it with the brazing method.
Of course, I was fixing genuine SOHC4 tanks.   ;)
Offline CBGBs
Re: tank repair
« Reply #16 on: March 27, 2007, 02:52:42 AM »
;D
