Author Topic: Main Jet Sizing  (Read 1088 times)
snoop
Main Jet Sizing
« on: March 26, 2007, 07:01:22 AM »
I am about to dive in to my carbs,  I understand the process very well but I dont get certain areas like jet sizing.  I hear people saying up the jet to a certain number.  Are the jets universal between bikes? Where would I get new jets that are not stock sizing?  Also how do the jet numbers work?
Re: Main Jet Sizing
« Reply #1 on: March 26, 2007, 07:31:32 AM »
Well you did not mention what bike it is. Jet sizes have a 3 digit number. 105 is smaller than 120 etc. How you jet your bike depends on if you are using a stock air filter set up or you are using pods. The exhaust system has an effect, open pipes take a richer mixture than a stock system so you may go up a jet size. It is all about reading your plugs to see if you are rich or lean. I would search the forum for the "plug chop"technique" which a lot of people use for reading plugs. Jets are pretty easy to get.
Offline Lumbee
    • My pics...
Re: Main Jet Sizing
« Reply #2 on: March 26, 2007, 07:36:31 AM »
"I'm not a welder, but I play one on HondaChopper.com"
snoop
Re: Main Jet Sizing
« Reply #3 on: March 26, 2007, 08:47:22 AM »
I have a cb550 and cb125.  I am learning to do carb adjustments on the cb125 first because it is a single then move on to the 4 carbs.  the cb 125 has an open exhaust and has a main jet #98
