Author Topic: What parts did you use ?  (Read 1767 times)
« on: March 26, 2007, 05:18:39 PM »
when you coverted your CB750 to twin front disc ?
Allthough I have done it, I never said what a cock up it was ;D ;D ;D...It looks right...it works OK...and at 185mph you can't tell it's a cock up. ;D ;D ;D ;D ;D
Chris has a mate who wants to do the conversion and like me, he hasn't a clue what the parts came of that we used.
The caliper arm that we started with was handed...the one on the right is straight but lines up perfectly.
What caliper arms did you all use. ?
Sam. ;)
Re: What parts did you use ?
« Reply #1 on: March 27, 2007, 11:29:41 AM »
bump ::) ::) ::) ::) ::) ::) ::)
Offline mcpuffett
« Reply #2 on: March 27, 2007, 01:13:30 PM »
hi sam , cben750 has done a detailed document on the subject with photos etc if you do a search you will find it  ;),   cheers mick.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #3 on: March 27, 2007, 01:25:18 PM »
I gota nifty brake line spitter from a M.Guzzi on my CB750 dual disc setup.. ;D
« Reply #4 on: March 27, 2007, 01:55:29 PM »
Did it Mick but it didn't say what model the caliper arms came from.
Sam. ;)
« Reply #5 on: March 27, 2007, 01:56:51 PM »
Thanks PT, it was the caliper arms that have me stumped.
Sam. ;)
« Reply #6 on: March 27, 2007, 04:55:54 PM »
Well Sam, Are you using stock fork legs? Mine is a K3 and it seems to me I just used another K arm. I probably have a dozen and they're all the same.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #7 on: March 27, 2007, 05:06:00 PM »
sam-- i haven't done the conversion on a 750, but i believe the early 750's have the same setup as the 550. in any case, i just used all parts identical to the left side. the only difference is that you lose the rubbers on the right side fender mount.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline mick750F
« Reply #8 on: March 27, 2007, 05:14:51 PM »
   Hey Sam...If you're looking for a conversion to use spoked wheels, then the Goldwing forks are supposed to be a straight up swap...I think...from reading posts here. If you want to go further, then later model dohc calipers(two pistons) and their mounting brackets are supposed to line up with sohc lower fork legs. I believe Sean(Scondon) has done the dohc caliper conversion so maybe give him a pm if you have questions. So, Goldwing forks from the era combined with dohc calipers with their brackets=good braking. ;D
Mike
Glosta, MA
« Reply #9 on: March 27, 2007, 05:39:29 PM »
Thanks guys, looks like BW has sorted it  ;).
The problem arose when we bought the doner bike.
It was a K4 but it had a DOHC CB900 front end on it.
Chris started looking round for the K4 front end bits and came up with a set of F1 forks and a caliper arm that was said to be off a K4.
When you are not sure what you are doing, people take advantage and tell/sell you anything.
In the end I found an arm that did the job with a bit of moding, but like the first arm, I hadn't a clue what it came off.
Anyway sorted now thanks. ;)
Sam. ;)
Offline justinmcgiver
« Reply #10 on: March 27, 2007, 07:28:58 PM »
I feel your pain...I'm doing a conversion and have managed to get three different "K" caliper arms, with two fifferent mounting brackets in my search for parts.  :-\
'74 CB750 K4 - Lake Placid, New York USA
