Author Topic: Help Identifying CB550 Header  (Read 4505 times)
Offline FunJimmy
  • Who you calling
  • Vancouver
« on: March 29, 2007, 06:21:58 PM »
I just won this header on Ebay and was hoping you could confirm the description.
Auction read:
This auction features a genuine Kerker header head pipe.
Fits Honda four cylinder between the 350 ~ 550. We're not exactly sure which.
Please use the details and photos below to determine application to your particular model.
Diameter of mounting flange at head 1 5/8 inch
Diameter of header tubes 1 3/8 inches
Diameter of tube at header exit 1 3/4 inches
Please see photos below to view mounting collar style and pipe bend for oil filter access.
Is this indeed a Kerker for a CB550?
Thanks
Jimmy
Re: Help Identifying CB550 Header
« Reply #1 on: March 30, 2007, 12:39:38 AM »
Fraid there is only one way to be sure and that is try and fit it!
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: March 30, 2007, 01:07:05 AM »
Fitment would be great but I haven’t got it yet.
Sure looks like a 550 pipe.
Measurements say it is, but is it a KERKER?
Can’t find any real good pics of a Kerker 4 into 1 anywhere!
Someone here knows what it is!
Later
Jimmy
Offline puppytrax
« Reply #3 on: March 30, 2007, 03:34:27 AM »
1 3/8" header tubes is kinda big...my 550's only use 1 1/4" tubes (4 into 4)...
I would think you'd lose some low end torque...
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline Kevin400F
« Reply #4 on: March 30, 2007, 04:02:39 AM »
550 exhaust ports are angled relative to one another.  Looking down from the top, the header spigots should look something like this (exaggerated, of course): \  /  \  /
If they're all basically parallel as it appears in the pic, there's no way its for a 550.
Kevin
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #5 on: March 30, 2007, 03:16:40 PM »
Kevin
Thanks for piping up. I wish I had consulted you before I laid down the winning bid.
I've always wanted a quality header like Yosh or Kerker.
Guess I'll have to relist her......or maybe find a bike to fit the pipe.
What do think it fits? CB400 maybe.
Jim
Offline Kevin400F
« Reply #6 on: March 30, 2007, 05:45:50 PM »
Measure the centerline-to-centerline pipe spacing between #1 and #4?  On a 350F/400F, the spacing is approximately 10 inches.  A 750 is approximately 12".   Keep us posted.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #7 on: March 30, 2007, 06:18:58 PM »
i don't have the time to do the unit conversion, but here are some exhaust specs that might help you:
http://www.sohc4.us/forums/index.php?topic=13519.msg161267#msg161267
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline jreich
« Reply #8 on: March 30, 2007, 07:19:56 PM »
Here are a couple pictures of the Kerker header off of my 500
Offline crazypj
  • I'm brill, me
« Reply #9 on: March 31, 2007, 01:00:09 AM »
Never found the Kerker to be particularly good quality, but they were the loudest ;D. (wasn't impressed by Yoshi either but don't think any of the good ones from 70's are still in business, most went bust before the 80's were done)
All the ones I saw/fitted had collector a bit further to the side it was going to exit.
You  can probably offload it to a 750 owner as it doesn't look like a 550 one to me.
PJ
Offline puppytrax
« Reply #10 on: March 31, 2007, 03:33:50 AM »
yes - if you look at the middle pic, and rotate it so that the collector is horizontal, then the head pipes have a decided downward angle, consistent with the 750 tilted engine (not upright like the 550). That plus the large pipe diameter would lead me to think "750".
But that's a good thing. Those are nice looking pipes. You should be able to get a good price.   ;)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #11 on: March 31, 2007, 09:07:47 AM »
Thanks for all the imput guys.
Those pictures confirm that it's a Kerker.
I just measured the collector extit on my CB550F 4 into 1 and it is 2".
This pipe claims 1 3/4". Wouldn't that suggest a smaller displacement?
Keep your coments comming.
Jimmy
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #12 on: April 02, 2007, 11:26:49 AM »
Kevin
My previous reply to your post was a case of mistaken identity.
If it seemed to be an unusual reply to your contribution, that was because I had earlier
emailed a CB400 specialist friend of mine, who is also named Kevin. I thought that he had stumbled across this thread and chose to address it here as apposed to my private email.
I just realized the error in identity when my friend Kevin emailed me his response to my question.
Sorry if my reply to your post seemed a little odd or presumptuous. Nothing personal intended.
Jimmy
Offline Chris Liston
« Reply #13 on: April 02, 2007, 04:08:02 PM »
Looks like a chrome MAC Header.  I think they look identical to the Kerker as most likely they copied the design.
1976 CB550F Cafe in progress
