Author Topic: Clutches and graphite oil  (Read 1585 times)
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« on: March 30, 2007, 10:10:59 PM »
Back in the early '80's, I installed a set of Barnett clutch plates and springs in my CB350F.  It worked real nice then.  Then in the mid to late '80's I started using engine oil with graphite (made by Valvoline or STP, can't remember) because it was marketed as being for high perfomance engines and there was no warning about wet clutches.  Well as time went by, the clutch would seize up when the bike sat for as little as 2-3 days.  It would only disengage after the engine was warmed up and after several stalls putting it into 1st gear.  After sitting for 12 years, the clutch would not disengage no mater what.  I had to pri the plates apart and it still seizes after a day of not running.  So now I am thinking, did the graphite oil do this?  Or is it something else?  Any one else have this experience?  I am thinking of getting a new set since these are over 20 years old and seem to be slipping now during acceleration and the new Barnetts are probably better.
« Last Edit: March 30, 2007, 10:12:32 PM by kslrr »
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline jabbadeznuts
Re: Clutches and graphite oil
« Reply #1 on: March 30, 2007, 11:43:34 PM »
Not only will you need to replace the clutch plates, but you'll also need to flush your engine to get out any and all additive residue.
'75 CB550
'82 Suzuki GN125 - glad to be rid of that thing.
« Reply #2 on: March 31, 2007, 01:23:54 AM »
The graphite has filled up the pores in the friction plates.  The clutch springs now squeeze all the oil out from between the plates making them stick together as they form a bit of a vaccum, until some oil can seep into them between the plates.  Then it slips because the oil film prevents disc to disc contact.
Not only are your friction discs contaminated, I believe your metal discs are, too.  Further, if there is any more graphite floating around in the engine/trans, it will find its way to replacement clutch disks for a repeat lesson in what-not-to-put-in-a-motorcycle-engine-with-a-wet-clutch.
Offline kslrr
« Reply #3 on: March 31, 2007, 08:05:04 AM »
Thanks guys.  I had a feeling that is what happened TT.  I will definitly flush out the engine on the next oil and filter change and maybe wait to replace the clutch playes until after 2 or 3 flushes.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline keiths
« Reply #4 on: March 31, 2007, 07:13:14 PM »
I put that graphite oil in my van in 1980 and the graphite was still leaching out of every crevice of that engine for the next 12 years and over 100,000 miles.
Offline kslrr
« Reply #5 on: March 31, 2007, 07:19:49 PM »
Not good news.  Anybody want to invest in companies that make clutch plates and oil filters.  I might be buying a few cases over the next year or so :(.
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
Offline Bodi
« Reply #6 on: April 01, 2007, 02:08:32 PM »
I doubt if graphite is an issue. Barnett plates are infamous for this cold lockup which gets worse as they wear in. Sounds like normal Barnett plates to me, nothing unusual.
Offline TomC
« Reply #7 on: April 01, 2007, 06:32:59 PM »
Hi kslrr
     I second what Bodi had to say. I had a CB450 with a Barnett clutch plates years ago. The clutch would get sticky. I would take the clutch apart check every thing and clean every thing. No problems ever found but the cleaning would get the clutch working again.
          TomC in Ohio
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline kslrr
« Reply #8 on: April 01, 2007, 06:35:41 PM »
Thanks Bodi and TomC.  My dispare has been lifted by that news.  So, a good engine flush, new oil (no additives), new filter and new clutch plates and I should be good to go :)
        1981 CB650 engine
Then 1972 CL175
        1964 Yamaha YGS-1T
