Author Topic: Widest front tire on stock rim?  (Read 1756 times)
Offline AHuff
« on: April 02, 2007, 09:51:59 am »
Will a 4.00-19 be alright on the stock 1.85 rim?
-Adam
eldar
Re: Widest front tire on stock rim?
« Reply #1 on: April 02, 2007, 10:42:11 am »
I guess I usually go with the other size so I dont know the conversion off hand. I use a 110/90-19 on the front. Works very well and look good too.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #2 on: April 02, 2007, 10:49:14 am »
I think a 110 is the biggest you can go on the front..
« Reply #3 on: April 02, 2007, 11:05:39 am »
-Adam
I would expect so, since that width tire is used on 1.85 rear rims routinely.  But, the manufacturer would know what width rim was required for the tire.  Have you looked at the manufacturrer web site for rim width recommendations?
Offline 75750SS
  • 75 750F, 2010 Concours ABS
« Reply #4 on: April 02, 2007, 11:06:58 am »
I'm currently running with a 4.10 19 front and 4.20 18 rear on my 75 750F.
Offline scondon
  • Mmmm......tasty bugs
« Reply #5 on: April 02, 2007, 11:31:00 am »
  I was looking all over for a 110/90-19 tire for the Lester front rim I acquired(2.15-19). I thought the 100/90-19 that I normally run on the stock rim would be too narrow. I checked Pirelli's specs and find the 100/90-19 is rated for a 2.15-2.5 rim. All this time I've been squeezing that skinny tire on a undersized 1.85 rim. Who knew :P :)
Offline AHuff
« Reply #6 on: April 02, 2007, 11:40:36 am »
Thanks for all the help thus far. First hand experience always appreciated.
According to this metric/standard calculator, a 110/90-19 is 26.8" tall, is 4.3" wide, and has a 3.9" sidewall. While the 100/90-19 is 26.1" tall, 3.9" wide, and has a 3.5" sidewall. I guess a 4.00-19 should slip in there just fine.
Thanks again.
