Author Topic: Help!  (Read 1273 times)
Offline griff6-5-zero
  • WNY CB Crew
Help!
« on: April 04, 2007, 08:43:15 AM »
whats the best way to clean the gasket and gasket sealer off the head without damaging??
It seems that I should have these clean as can be, but I can't get down to the mating surface. I have scraped a little with a chisel, but afraid of damaging. Is there some type of solvent that I can use?
Thanks in advance  ???
gold01ca
Re: Help!
« Reply #1 on: April 04, 2007, 09:29:37 AM »
whoa griff! keep the chisels/scrapers etc. away from the aluminum, especially gasket mating surfaces.
should be a spray on gasket remover product down at your auto supply shop, permatex or something.
after the product does its job and lifts/loosens the old gasket material, use a plastic scraper or fine steel wool.
cheers!
  • WNY CB Crew
Re: Help!
« Reply #2 on: April 04, 2007, 09:38:28 AM »
Let me post a pic later.
Offline mb3000gt
Re: Help!
« Reply #3 on: April 04, 2007, 10:03:58 AM »
you can buy gasket remover at any auto parts store. use it outdoors as the fumes are terrible. it may take multiple applications but it always works. use a plastic scaper or a putty knife. a metal scraper will easily take out a chunk of aluminum if your not careful.
  • WNY CB Crew
Re: Help!
« Reply #4 on: April 04, 2007, 10:49:49 AM »
Thanks, I'll try this tonight.
Offline Jonesy
  • Shop Rat
Re: Help!
« Reply #5 on: April 04, 2007, 11:07:32 AM »
You can get a special gasket remover that fits on the end of a drill or die grinder. It's a rubber disc with numerous rubber "fingers" that gently remove the gasket.
  • WNY CB Crew
Re: Help!
« Reply #6 on: April 04, 2007, 12:03:03 PM »
The gasket came off but there is a resdue left behind. I'm thinking this is gasket sealer. I say gasket because it looks like there may be part of the gasket still there. Maybe the gasket split and left some on there? It feels smooth though and I was able to chip some away like it was rust. I'm going to get some gasket remover. If need be, I shall post a pic. Thanks guys..
Offline Jonesy
  • Shop Rat
Re: Help!
« Reply #7 on: April 04, 2007, 12:20:41 PM »
Try spraying a little brake cleaner on it and rubbing it with a fine Scotch-Brite pad.
