Author Topic: Honda Interceptor Cam troubles??  (Read 2375 times)
Offline LoopsAndLogic
  • Dang IT!!!
« on: April 05, 2007, 02:24:01 PM »
Hello,
 I've purchased a 84' Interceptor VF500 with 7k on the clock.
Purchased from the 3rd owner, and well, he had some engine trouble...... He thought he had a head gasket leak but what he
really had was a water pump mechanical seal that was allowing water into the oil.
So I have the privilege of replacing all the cams, heads, and seals.
Well, after 2 years, I've replaced and secured all NOS head gaskets. While I was using plastic gauge to set the cams, I noticed he mixed up the cam holders.
I can tell, because I can't even get accurate readings. Meaning, while all the cam holders are torqued halfway between the lowest and maxim lbs. per foot that the oem shop manual says. The readings on each cam bearing journal are Way OFF!
If I understand correctly, the wider the plastic gauge is mashed up against the holder, and compared against the size chart, the smaller the gap is between the holder and cam????
 So my question is, would it be okay if I were to place all the cam holders to the lowest torque setting to make certain that the cams wont seize??
 Would it cause excessive ticking from the topend or wear??
I am planning on looking for a replacement motor, but I thought I would give it my best! Hence, this is my first time setting 4 cams :o :o
Thanks for the help.
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline crazypj
  • I'm brill, me
Re: Honda Interceptor Cam troubles??
« Reply #1 on: April 06, 2007, 08:47:11 AM »
As long as its torqued to spec you shouldn't have any problems (except you bought a V-4  ;D)
 Its a ticky clicky motor anyway, I don't like them (any of the V-4's, although the 500 was best IMO))
 I'm probably not the best person to give advice ;D
PJ
  • Dang IT!!!
« Reply #2 on: April 06, 2007, 10:13:53 AM »
Well, would someone with the best advice please come forward ;D ;D ;D ;D :D :D :D
I know, its not a VFR but I am hoping it will run for at least a summer. I only paid $250 ;) ;) ;)
Anybody familiar with the 1st year Interceptors???
Any help is appreciated
My rides:
Past Rides:
Online dusterdude
« Reply #3 on: April 06, 2007, 11:14:15 AM »
contace heffay,i think he`s had one or two of them bikes
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
  • Dang IT!!!
« Reply #4 on: April 07, 2007, 11:15:18 AM »
Contact Heffay? Will do and thanks for the help.
Any of you guys know where I could find a website like this, for the VF series, and not the VFR??
Thank you
My rides:
Past Rides:
Offline crazypj
  • I'm brill, me
« Reply #5 on: April 08, 2007, 06:45:06 PM »
For $250 you got a bargain, hell I  think I could get to like one at that price ;D ;D
I am familiar with first year, thats why I don't like them much. (the 750 was a disaster)
PJ
  • Dang IT!!!
« Reply #6 on: April 10, 2007, 07:28:23 AM »
Well, since you are familiar with this bike, do you think setting the cam holders to there lowest torque value is okay??
I know the 83' 750 was a disaster, but I thought they fixed the problem in the 84' - 86' models??
Thanks,
LL
My rides:
Past Rides:
Offline DarkRider
« Reply #7 on: April 10, 2007, 11:31:33 AM »
Heh...I currently own a 1st gen VF750F...Great bikes when they are running well. try VFRworld. They have a section of the forum devoted to the first gen bikes (VF and VFR)
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
  • Dang IT!!!
« Reply #8 on: April 10, 2007, 05:05:23 PM »
I did, but they don't respond nor is there response time like SOHC4.
Do you know of any other sites for the VF Interceptor?
Thank you
LL
My rides:
Past Rides:
