Author Topic: clutch woes  (Read 921 times)
Offline hymodyne
clutch woes
« on: April 07, 2007, 04:10:04 PM »
thanks to hondaman, I've got my bike not only running, but moving as well. after a winter rebuild, few things could be more frustrating than to have a bike that's running, but not moving. after tearing down the clutch again, I found the problem, four misplaced washers that were screwing up the return rates on my clutch springs. I checked an exploded view of this clutch (thanks csml) and I discovered that the four washers I had weren't part of the set up at all. with them removed and bolts torqued to specs, she not only runs, but rolls as well, although next I have to go in and tighten head nuts again, lots of white smoke from the left side exhaust and an oily #1 plug.
elated although smoking like something created by professor fate, I was ready to take an unlicensed spin around the drive of my house, the first movement not related to the flintstones since last july... I pull in the clutch lever, and shift into first, then, nothing! just like its supposed to work...engine running, bike in gear, not moving, I slowly begin to release the clutch lever and... she rolls forward, like she's supposed to. elated, I squeeze the clutch in again and... snap! broken clutch cable...
damn.
hym
Offline 750goes
  • it will live
Re: clutch woes
« Reply #1 on: April 07, 2007, 05:28:22 PM »
glad its working for you........oh and the clutch cable...........#$%* happens....... :)
Offline UnCrash
  • Pass
    • My Blog
Re: clutch woes
« Reply #2 on: May 04, 2007, 05:01:57 AM »
Man, I can relate :'(
I've been working on my crusty 78 Cb750F and thought I would be able to finally ride it this weekend.  I'm registered, insured, licensed, rebuilt brakes, etc....
This morning the damn (good girl) wouldn't start.  I zip tied my clutch cable to the fram down tube and noticed that the clutch was stiff.  Working in a little lube, the thing just snapped right at the lever.   >:(
Better in my garage than out on the streed I guess.
I'll order one up from Motion Pro.
Where did you get yours from?
Ben
Offline hymodyne
Re: clutch woes
« Reply #3 on: May 05, 2007, 05:14:54 PM »
cycle-recycle part two. keep your old insert on the cable that goes into the left side cover, though. the one they sell is the wrong size..
hym
