Author Topic: piston ring order.....  (Read 1113 times)
Offline turboguzzi
« on: April 11, 2007, 01:17:46 PM »
Fresh piston rings landed on my desk and am ready to assemble. can anyone confirm that the order/direction I am putting them is fine?
Was expected to see a "top" marking on the rings but these original honda rings didn't have them, only a "R" and 75 (for .75mm oversize) on the same side,  so just making sure
this is the order they were inside the package:
top ring: grey color - direction does not seem to matter as both edges look the same
second ring - dull chrome finish - with little chamfer facing down
oil rings - no doubts here
can anyone confirm or correct?
Thanks
TG
Offline cappy
Re: piston ring order.....
« Reply #1 on: April 11, 2007, 01:19:22 PM »
Should be a 'R' stamped on the top side.
GTR1400 KAWASAKI CONCOURS 08'
T500 TITAN 75'
YZ250 82'
CB550 77' BUILDING
Offline turboguzzi
« Reply #2 on: April 11, 2007, 01:27:31 PM »
Thanks, yeah that R.
so question narrows to: grey ring first (on top) , chromed ring second or the other way around?
TG
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #3 on: April 11, 2007, 01:45:44 PM »
I thought the chromed ring was the compression, but I could be wrong.
There I said it, let the confusion continue. :-\
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
« Reply #4 on: April 11, 2007, 01:51:27 PM »
Chrome ring is the top one with the chamfer at the top facing the combstion chamber.
Second ring anyway up unless marked.
This is only from memory, can confirm tomorow.
Sam.
Offline turboguzzi
« Reply #5 on: April 11, 2007, 03:36:10 PM »
thanks Sam & all
checked myself the manual again and again and the only thing mentioned is "marks towards top" but no mentioning of different rings. both are for compression by the way.
Sounds like the chromed should indeed be the first, it's just that in all the four packages the rings where in the same order within the box, gray one first, chrome ring second and then oil rings. that put me in doubt.
cheers
TG
« Reply #6 on: April 12, 2007, 05:03:11 AM »
Packaging means nothing! ALL marks go upwards, chromed ring in top, plain steel in second
