Author Topic: Fuel flow rate test.....  (Read 1362 times)
Offline yd72
« on: April 11, 2007, 08:37:34 PM »
Anybody can help?
I am thinking to mod my petcock of my honda cb350f because those nos part is really expensive? Anybody know the acceptable fuel flow rate from petcock to carbs so that enough fuel is supply to power (accelerate) the bike? Anybody has done the test on the fuel flow rate?
Thanks first.
Chris
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Fuel flow rate test.....
« Reply #1 on: April 11, 2007, 09:00:41 PM »
That is something that I would like to know also.  Since I have a hot cam in my 350, I have opened up the fuel passages between and in the carbs just to make sure I get enough.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline 750goes
  • it will live
« Reply #2 on: April 11, 2007, 09:14:26 PM »
Just install larger inside diameter fuel line - the bike will not run better as carbs will control the flow of metered fuel. But larger pipe equals greater flow.....
« Reply #3 on: April 11, 2007, 11:05:40 PM »
Here are some napkin calculations:
50 MPG/ 50 miles per hour.  One gallon per hour consumption.
A one quart jar (1/4 of a gallon) would drain in 15 minutes (1/4 of an hour) if that were your fuel tank.
If your bike got 25 mpg @50mph, you'd use a quart in 7.5 minutes.
12.5 mpg : a quart in 3.75 minutes
Attach hose on petcock and aim it at a one quart jar.  Turn on petcock, time how fast is fills.  If it takes longer than 4 minutes, you have a restriction issue.
How bad is your gas mileage/ fuel consumption?
About larger hoses:
A bigger hose does allow higher liquid flow rates.  However, the flow rate is limited by the smallest restriction in the flow path.  Using larger hoses and smaller I.D. size fittings negates any benefit from the larger hoses.  Unless, of course you are talking very long hoses.  But, that is another fluid dynamics problem.
By the way, I used a pink napkin with floral embossed pattern.  Some might say it was rose colored.  ;D
Offline scunny
  • don't call me expert
« Reply #4 on: April 11, 2007, 11:19:03 PM »
you sure can't argue with a pink napkin.
nicely put TT
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline 750goes
  • it will live
« Reply #5 on: April 12, 2007, 07:09:25 PM »
If you are colour blind , do I still have to think in colour as well ??  :)
« Reply #6 on: April 12, 2007, 10:27:09 PM »
If you are color blind, how would you know you were thinking in color? :-\ ;)
Offline 750goes
  • it will live
« Reply #7 on: April 12, 2007, 10:48:56 PM »
you didn't interpret my reponse right...or I wasn't erudite...not sure... :)
