Author Topic: Vesrah gasket set  (Read 563 times)
Vesrah gasket set
« on: February 11, 2025, 01:25:11 PM »
 I bought a Vesrah VG157-557 gasket set, I'm not sure it includes the o ring for the main oil passage between the cases in front. I don't see it listed in the 7-piece seal kits either.
  If I search 1978 cb750 in partzilla, they have it listed as 18x3mm.  I'm wondering if I should buy a few?
Re: Vesrah gasket set
« Reply #1 on: February 11, 2025, 01:42:09 PM »
Why not buy viton ones from a local supplier, should be same on all 750
« Reply #2 on: February 11, 2025, 02:56:01 PM »
  The term local supplier around here is a joke. Our bearing house closed, the good auto/hardware became a railroad supplier, the one remaining hydraulic hose company only sells wholesale, we do have a good NAPA area warehouse store however, that might be a source.  Edit: NAPA has 19X3 but no 18X3
« Last Edit: February 11, 2025, 03:46:48 PM by Don R »
Offline newday777
« Reply #3 on: February 11, 2025, 04:06:55 PM »
Hondaman has 18x3 orings. It fits the neutral switch.
Stu
My current rides
Prior bikes....
« Reply #4 on: February 11, 2025, 04:12:28 PM »
 I'm going to measure one, it looks bigger to my micrometer eye. I found them in buna n for $.60 each but have to buy 40.
« Reply #5 on: February 11, 2025, 08:34:48 PM »
I bought a bunch of o-rings to cover all of them for a CB750. Min 25 pack, some 50 pack.
Most of them viton.
For early and late heads (under cam holder) and thick head gasket and stock.
 Lifting heads and cylinders as I did a few years ago needed a good stock home. Buy Honda stock $$ a big no-no.
I got mine from an eBay seller or 2 in UK. Bearings and  sealer seller.
A 50-pack of o-rings to oil filter too. But not viton found for this.
The rings supplied with filters are always too thin, not 4.5mm.
« Last Edit: February 11, 2025, 08:37:29 PM by PeWe »
« Reply #6 on: February 14, 2025, 05:13:18 PM »
 I noticed that Hondaman sells o ring kits, properly sized and everything. It's in the sponsor page.
