Author Topic: Bringing a 750 K1 back to life  (Read 23010 times)
Offline Laids
Re: Bringing a 750 K1 back to life
« Reply #50 on: April 11, 2025, 07:39:46 AM »
And crimping on the new ones?
There’s a few videos on u-tube showing how to attach the crimp ring.
Offline BenelliSEI
  • 1969 cb750
« Reply #51 on: April 12, 2025, 06:20:30 AM »
I’ve seen those but mine didn’t turn out the way the video shows!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #52 on: April 12, 2025, 07:43:11 AM »
I miss Marcel, he did a great job on mine.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Laids
« Reply #53 on: April 12, 2025, 10:46:29 AM »
Marcel did my KO gauges about 12 years ago. I think it was about $750 then.
Offline Laids
« Reply #54 on: April 12, 2025, 11:02:56 AM »
I did the faces on my K8 cafe about 15 years ago they were sticker type. On that I cut the crimp ring then epoxied and clamped it. Still holding but not a concours job, mostly hidden underneath.
For these K1 gauges I made a jig that will hold the gauge firm to allow the crimp ring to be tapped closed a little at a time. I saw it done somewhere else, I think it should work.
Just waiting for the Yamiya faces to arrive to see if they are transparent on the back like the originals.
Offline Laids
« Reply #55 on: April 12, 2025, 11:06:50 AM »
You can see the gap in the crimp ring in the top pic. In the last pic you can see the open crimp ring.
Offline Laids
« Reply #56 on: May 15, 2025, 03:05:00 PM »
To bring this project up to date, I’ve been chipping away and made much progress. Gauges are on , all cables, wiring is connected. Connected but no power, I finally hit the wall with my limited electrical knowledge. Called my friend Bill M , longtime wrench with 50 years of experience Who kindly came over. Problems solved , everything working.
Now ready for startup. Started right up but oil light didn’t go off so I shut it down. It sounded good so I too took a pressure gauge off another bike to put on to make sure. Started with 70 to 80 psi showing so for now ignoring the oil light, still a little disconcerting with that bright red light in your face crying warning.
Next is unpacking the tank which was in a container with the side covers and emblems , all were included when I bought it. I had a quick examination of it earlier but when I fitted it to the bike I noticed where it fits on to the rubber holders on the neck it was wider apart than any tank I’ve seen, see pictures compared to a K4 tank.
Test ride tomorrow.
Offline BenelliSEI
  • 1969 cb750
« Reply #57 on: May 15, 2025, 04:21:37 PM »
Bike is looking really fantastic. Did you check if the oil pressure warning light is a switch or wiring problem? Leave that pressure switch alone for a while. I’ve had a few that sorted themselves after a few heat cycles!
The tank I just fitted to the K1 has the same problem. It’s a lot wider across the rubber mounts than the original too! Thinking of machining up some plastic ones that are a bit taller than the rubber “knobs”…..?
Offline Kelly E
  • Geriatric Hooligan
« Reply #58 on: May 15, 2025, 04:50:00 PM »
I had my nephew 3D print a pair of oval shaped "knobs" for the 77' KZ 1000 to keep the tank from sliding forward a 1/4" and smacking the fuel petcock on the back of the valve cover. Worked out great.
He only had white so I painted them black so I couldn't see them.
« Last Edit: May 15, 2025, 04:51:49 PM by Kelly E »
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline BenelliSEI
  • 1969 cb750
« Reply #59 on: May 16, 2025, 05:16:20 AM »
Yep… same idea.
Offline Laids
« Reply #60 on: May 16, 2025, 05:48:18 AM »
I checked the connections, I’ll leave the switch for while to see if it corrects itself. They can be a bear to to get off.
Offline newday777
« Reply #61 on: May 16, 2025, 06:26:13 AM »
A 12 point socket is what to use on the oil pressure switch
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #62 on: May 16, 2025, 06:51:10 AM »
Does the light go off if you pull the wire off the switch? It sends a ground to the lamp. That confirms the wiring is all OK.
« Reply #63 on: May 16, 2025, 07:26:38 AM »
 If someone tried compressed air or freezing water in a tank to blow a dent out, that would spread them apart. I've trimmed the rubber knobs for a fibermold tank.
« Reply #64 on: May 16, 2025, 10:01:01 AM »
Bike looks great!  Wide tank looks odd, have not seen that before...
Offline ofreen
« Reply #65 on: May 16, 2025, 11:36:28 AM »
Yes, that is what it looks like.  I am embarrassed to say I did that to mine about 35 years ago when I thought I had a bright idea.  Didn't take much pressure to do it either.  I pulled it back in with padded ratchet straps, but it was a memorable bonehead move on my part.  The dent did pop out a little. ;D
Greg
'75 CB750F
Offline BenelliSEI
  • 1969 cb750
« Reply #66 on: May 16, 2025, 02:04:55 PM »
I don’t think mine’s been worked. It had an original plain chrome trim strip so I think it was a K0 tank. When I fitted it to the K1 it is a bit loose. I’ll make some “extended” rubber “knobs” next time I take it off…..
Offline Laids
« Reply #67 on: May 16, 2025, 03:51:46 PM »
Got out for the test ride today, just into town and back, about 10 miles. One half highway the other back roads. Acceleration was good but some popping on deceleration. All round felt good.
I took the oil pressure gauge wire off and grounded it against the engine, blew a fuse.
Offline BenelliSEI
  • 1969 cb750
« Reply #68 on: May 16, 2025, 05:49:50 PM »
Bike looks stunning!
Check the bulb holder? Should have power when the key is on and gets a ground from the switch…..
« Reply #69 on: May 21, 2025, 08:03:18 AM »
Could be a bit lean or exhaust leak?  Bike looks good, nice job!
Offline Laids
« Reply #70 on: May 26, 2025, 03:14:56 PM »
As to the wide tank anomaly, here’s a pick of the 71 tank petcock and my 74 never been used tank  (till now ) petcock, notice the angle differences. Clearly the 71 tank has been tampered with.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #71 on: May 27, 2025, 07:38:14 AM »
very nice.
strange petcock issue.
1973 CB 750 K3
Offline Shtonecb500
    • Youtube profile
« Reply #72 on: June 06, 2025, 06:15:40 AM »
very nice.
my wrinkle tank is expanded bc of someone previously using air inside of it, my petcock does the same thing.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline BenelliSEI
  • 1969 cb750
« Reply #73 on: July 17, 2025, 10:08:13 AM »
Chris….. Cleaned up (a bit) my K1 today. Looking forward to meeting up tomorrow!
Cheers, John D.
