Author Topic: Red glowing clutch cable!  (Read 1648 times)
Offline Teddyhoeg1982
« on: February 16, 2025, 01:11:10 PM »
I have been working on restoring this 1977 CB500. Did a few runs last year but never got it to run right. I just got done putting on a Kokusan electronic ignition and wanted to start the bike, but then saw that my clutch cable was glowing red hot when I turned over the starter.  :D
Guess my ground from the battery negative pole to frame and motor is not making connection and somehow I got ground to the starter through my clutch cable… Still trying to figure out how this could happen. I got the frame powdercoated last year, but seems I did not make good enough connection at the engine hanger bolt, so i will remove it and remove the paint.
« Last Edit: February 17, 2025, 01:09:07 PM by Teddyhoeg1982 »
Re: Red glowing clutch cable!
« Reply #1 on: February 16, 2025, 01:15:21 PM »
You need to remove the powder coat from either side of the mounting bracket so the cable contacts steel and so does engine case, you will probably have melted the loom up by the coils as well
« Reply #2 on: February 16, 2025, 06:02:06 PM »
There is a green wire in the main harness with an eyelet, that also needs to have a good connection to the frame. The connection may be under the seat near the battery, or at one of the ignition coil mounts under the fuel tank, depending on the model. Like Bryan mentioned, check for melted insulation. :(
Offline Tracksnblades1
« Reply #3 on: February 16, 2025, 06:26:02 PM »
Make sure your alternator still works..those bad grounds can cause havoc on circuits that aren’t designed for
High amperage…
Just wondering why your clutch adjusting nuts are on the same side of the bracket…?
Wrong cable..?
Age Quod Agis
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #4 on: February 16, 2025, 07:06:55 PM »
High amperage…
Wrong cable..?
That's where the nuts were located from the factory. All my bikes and  bikes I have owned are in that configuration.
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #5 on: February 16, 2025, 09:19:04 PM »
That is a K3 500, its a rare model same as 550 but smaller bores, that is if it is a 500 and not a 550!
« Reply #6 on: February 16, 2025, 11:03:44 PM »
those nuts are correct,both on top.
« Reply #7 on: February 16, 2025, 11:20:36 PM »
One serves as a locknut for the other nut.
Offline Oddjob
« Reply #8 on: February 17, 2025, 07:31:02 AM »
The 500 has a completely different clutch activation design. No external arm.
Not the 500K3, it has what is essentially a 550 bottom end with a 500 top end. I think they were using up old stock in the factory and fitted what they had left from 500 and 550 production runs. As Bryan says, quite rare, not that many made by Honda. Note the PD carbs and the CB550K3 style exhausts, not the tulip bulb 500 type. Never seen one in the flesh, might be the first I've seen an actual picture of, before that just parts book illustrations.
« Reply #9 on: February 17, 2025, 08:20:41 AM »
That was what the 500 K3 was, i have somewhere a K3 parts book listed on front cover as 500/550 and in the last suplement for the 550 manual there are different carb settings for 500 and 550 both on PD carbs, as far as i can tell from parts book the only difference was barrels and piston kits
Offline rotortiller
« Reply #10 on: February 17, 2025, 09:00:24 AM »
The best thing you can do with any main ground is to install it to the engine surface under a frame lug. That way the starter which has the largest draw has the best low resistance connection to the battery. No worries about paint insulating. I do not mess around removing frame paint with this option available.
Offline Oddjob
« Reply #11 on: February 17, 2025, 09:07:41 AM »
I would recommend putting some drain tubes onto the carb float bowl overflow spigots, if the carbs overflow all that petrol will either corrode/affect the crankcase paint or worse drop down onto the exhausts and start a fire. Or both  ;)
« Reply #12 on: February 17, 2025, 10:52:28 AM »
Got some marshmallows?
« Reply #13 on: February 17, 2025, 01:11:34 PM »
I grounded the connections on both sides down to metal and gave them some WD40 for protection. The bike started right up! I have had quite a lot of problems getting this bike to run right last year, maybe this ground issue has been the problem. I am curious to take it for a run tomorrow and check.
« Reply #14 on: February 17, 2025, 01:15:44 PM »
There is indeed a green ground wire at the coils - it seems fine. But I will take off the coils tomorrow and check that they also have good ground to the frame.
« Reply #15 on: February 17, 2025, 01:17:03 PM »
High amperage…
Wrong cable..?
The bike would never charge, it is an issue I have not come to yet. Plan was to mound a modern combined rectifier/regulator and see from there. I do not believe it is the stator.
Offline willbird
« Reply #16 on: February 17, 2025, 01:17:45 PM »
Many years ago a couple German guys came to our small Ohio town. They came to my dads machine shop to have some parts made. They could get talk English fairly well but one mentioned "this part gets warm when the machine is running". My dad asked "how warm?"....and the guy replied "red warm" LOL.
Bill
« Reply #17 on: February 17, 2025, 01:20:01 PM »
Here in Denmark these were quite popular. We never got the 550K models, but the 550F models were sold here. If you wanted a 500, in 1977 you would get this 500K3. Except for the lower CC, only other difference I have found from a 550K3 is the PD carb jets and needles which are specific to 500K3 and a headache to find. I had to buy a whole spare bike to get the right carb internals.
« Reply #18 on: February 17, 2025, 01:21:53 PM »
Was the clutch cable damaged by the heat?
« Reply #19 on: February 17, 2025, 01:22:25 PM »
Yes I have them lying around, just not mounted currently. Actually the engine case is raw aluminium, I never got it painted. Which I now regret, since I can see that over the winter it created quite some corrosion. Plan is to pull the engine out and get it painted, once I can confirm that everything runs perfectly. Now I though regret I never got it done when I had it out of the frame, when the frame was powdercoated.
« Reply #20 on: February 17, 2025, 01:23:13 PM »
It seems fine, but it got a different color. I will replace it, since it has probably weakened it - I do not want to end up stranded with a broken cable.  :)
« Reply #21 on: February 17, 2025, 01:24:32 PM »
This time I indeed mounted the cable directly to the engine surface, under the clutch cable bracket, instead of on top.
« Reply #22 on: February 17, 2025, 01:37:14 PM »
From the factory it was on top BUT the bracket had no paint on either side at that point
« Reply #23 on: February 17, 2025, 01:53:31 PM »
How would it be protected against corrosion then?
« Reply #24 on: February 17, 2025, 02:33:30 PM »
It wasnt as such but the unpainted steel was tight against the alloy crankcase and the big cable terminal
