Author Topic: CB350F Tank Badge interchangeability  (Read 601 times)
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« on: February 25, 2025, 01:52:14 PM »
I have been looking for some descent tank badges for my replacement tank for my CB350F. They were proving to be hard to find.
I was looking at my CL200 and the dimensions were identical. Looking at the schematic they had the same pin arrangement as the CB350F.
I found a set on ebay from a CB175 K6.i asked the seller for the dimensions and they were identical to the 350F including pin location. The contour was the only difference..
I assumed they were plastic. I was going to see if I could heat up (boil) and re contour to match the tank . I was pleased to find out when they arrived today that they are made from a very malleable pot metal.
They are all cast with the product code on the back.
So these will all work.i am sure there are many others
333=CB350F
342=CB175
378=CL200
« Last Edit: February 25, 2025, 01:54:15 PM by Ozzybud »
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Offline Flyin900
Re: CB350F Tank Badge interchangeability
« Reply #1 on: February 25, 2025, 01:55:03 PM »
Good tip and as you noted the interchangeability.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Online Rayzerman
« Reply #2 on: February 26, 2025, 06:49:27 AM »
Your source please!!  I got a plastic set and have to heat and re-contour slightly.  Originals were cast, I'd prefer that.  These plastic ones are fine, but I have to repaint the white to get the correct shade (their paint was thin and a bit yellowish).
Offline Ozzybud
  • Honda Lover
  • Honda Lover
