Author Topic: Tire Mounting Lube/Paste Alternative?  (Read 1565 times)
« on: February 28, 2025, 09:13:47 AM »
I‘ve always spray on a bit of “Windex” when mounting tires, but decided to buy some of the real stuff. Unfortunately it comes in huge quantities and is expensive. Stumbled on this alternative and will be trying it out. What do you use?
“Anyway, for some reason I figured I would share it here in case anyone decides they need some. The old school backyard was to simply use some dish soap and water. This is fine I guess, but water has its downsides with wheel coroasion etc. I took that idea and slightly changed it.
Grab a jug of your favorite antifreeze/coolant and simply mix a little up with some car was soap ( or dish soap)
My thoughts are that it makes a slick enough formula to easily allow your bead to slide on to your wheel, plus we know that antifreeze is safe for your rubber ( think hoses ) and you get the nice benefit of corossiob resistance thanks to all the nice additives your antifreeze. The formula is not so slick that you have to worry about tire spinning, and dries realativly fast.
To sum it up:
Cheap and readily available
Alloy and steel wheel corossion protection ( Remember I live in Michigan)
Makes for easily mounting
Dries quickly”
« Last Edit: February 28, 2025, 11:11:36 AM by BenelliSEI »
Offline Mark1976
Re: Tire Mounting Lube/Paste Alternative?
« Reply #1 on: February 28, 2025, 11:09:52 AM »
I ‘ve always spray on a bit of “Windex” when mounting tires, but decided to buy some of the real stuff. Unfortunately it comes in huge quantities and is expensive. Stumbled on this alternative and will be trying it out. What do you use?
To sum it up:
Dries quickly”
As long as it dries, yer good to go.
Report back.....
Start with the end in mind...
Online scottly
« Reply #2 on: February 28, 2025, 07:45:40 PM »
Who are you quoting, John?
« Reply #3 on: February 28, 2025, 08:52:00 PM »
No idea….. a post on some place that seemed mostly devoted to “oil threads”. Not sure if I can even find it again, but I’ll brew up a small amount and try it. Mostly I was curious what others are using?
« Reply #4 on: March 01, 2025, 03:20:48 AM »
I have friends that use WD40 when they don't have any commercial tire lube on hand.
« Reply #5 on: March 01, 2025, 05:39:55 AM »
Stu….. I’m cautious about using stuff that leaves a residue. Heard stories of tires moving on the rims after a “panic stop”. Probably would never happen, but I can see the possibilities?
Offline BallAquatics
  • Wrenching & Riding
    • My Life with Motorbikes
« Reply #6 on: March 01, 2025, 08:47:59 AM »
I've used dish soap & water in a spray bottle for years now.  Have never really seen any signs of wheel corrosion or any other down-side for that matter.  Best of luck with whatever you choose!   ;)
Offline denward17
« Reply #7 on: March 01, 2025, 09:47:16 AM »
+1 That's what I have used as well.
Offline CycleRanger
  • No comment about being an
« Reply #8 on: March 01, 2025, 10:14:56 AM »
Same. Sometimes just a little plain water is even enough.
« Reply #9 on: March 01, 2025, 10:55:20 AM »
I have used wd40 to change inner tubes at the trailhead on my dirtbike...no problems with the tire slipping on the rim and I have not really found wd40 to leave any kind of sidnificant residue.  There are 2 major differences between my dirt bike though, and they are contradictory.  First is the presence of a rim lock, thats gonna really discourage tire slippage.  Two is  that tires may be run as low as 12psi, very rarely up to 20.  That is gonna tend towards encouraging slippage.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #11 on: March 01, 2025, 03:08:11 PM »
Offline lash
« Reply #13 on: March 02, 2025, 07:28:44 AM »
Try this John. Get it at Royal, works great.
« Reply #14 on: March 02, 2025, 08:19:25 AM »
Neat. Will do!
