Author Topic: 3 years, 3 slaves (hydraulic clutch failures)  (Read 881 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« on: February 28, 2025, 05:22:17 PM »
Risque title sums it up.
The FJR hydraulic clutch slave took a dump .. again.
Third time having ordered a replacement from ebay.  2022, 2023, and now.  Some pretty short lifespans considering it was in my possession 4 years before the first one quit.  And the bike was 12 years old at that point
Junkyard replacements because the oem diagram sells it as a complete unit. Charging a kings ransom for new in box.  The allballs seal kit is a gamble on fitment.  Some model years just be different *allegedly*
Would really like to know what is killing these things.  Best guess on the lastest failure it spent a night in a sub freezing temperature.  But the other unit survived life outdoors in TWO sub-zero Kansas winters before calling it quits.  The water content of dot 4 couldn't have gotten that high after a year in the desert could it?
The FSM says use brake fluid.  But if the hydraulic unit is going to crap out, its tempting to flush it and try some alternative.  Maybe one that conditions the seals better.
Thanks for reading about my woes
Re: 3 years, 3 slaves (hydraulic clutch failures)
« Reply #1 on: February 28, 2025, 07:14:18 PM »
How many miles on the original? How many miles on the junkyard replacements?
Offline Alan F.
« Reply #2 on: February 28, 2025, 07:52:56 PM »
Is DOT5 compatible with the materials in the system?
I use this for o-ring compatibility:
 https://mykin.com/rubber-chemical-resistance-chart-3
  • Holy Cow! I'm a
« Reply #3 on: March 01, 2025, 04:39:01 AM »
In terms of mileage..  First failure came up after i put 45-50kmi on the machine.  Not knowing if it had already had a slave replaced in its first 35k of life.
That was January 2022.  The junkyard part was a gently used ebay item from 2006.  Got 20kmi out of it.
November 2023, put on another salvaged part from 06, then basically parked the bike.  6,000 miles for 2024.
Now its February 2025 and the bike is awaiting its 3rd semi-annual transplant.  Scored a takeoff from a 2010.
Hope the all balls seals will fit this piston. Confirmed last night the kit is not a match for the '06 slaves.  Having dug out the left over from 2023.
The possibility of cleaning and reinstalling may be viable.  Little spots of visible wear on the cylinder gland, although the fit feels loose.
Should probably inspect the piston on the handlebar too.
[/Lamentation]
Its an older model, but might be able to run dot 5.2 - uncertain if a mineral-based clutch fluid would fair any better.
« Last Edit: March 01, 2025, 04:50:38 AM by BomberMann650 »
  • Holy Cow! I'm a
« Reply #4 on: March 06, 2025, 09:04:18 AM »
Issue resolved (for now)
The widely available rebuild kit was a match for a 2010 slave cylinder.  Had to polish the junkyard replacements bore as things were a bit... Junkyard-y
Will see how long this holds out. If the issue rears its head in the future - may search for another 2010 in better condition.
« Reply #5 on: March 11, 2025, 08:16:33 PM »
 I'm glad to hear you got it going.
Offline spotty
« Reply #6 on: March 11, 2025, 08:56:48 PM »
i've had the same problem with the vmax, which uses the same internals for its clutch slave, i've got 3 slaves, and it took two rebuild kits to get one of them to work, very frustrating but fixed now
i blame Terry
