Author Topic: Losing 2 cylinders when warm - CB750K2  (Read 25516 times)
Offline gotorx7
    • DaveWinfield.com
« on: March 03, 2025, 11:37:19 PM »
Hey everyone..
New (to me) bike that I've serviced - timing, tappets, carb sync, oil, filters and some cosmetic stuff.
I took her out for a test drive late last week, did about 15Kms, and it was running great, I was very happy.
As I got close to home and started the climb up the 1000 ft hill to get there, I lost power.  Struggled home slowly, and thought (belatedly) that it might be a vacuum lock (cap not venting).
So cleaned the cap in the ultrasonic bath, blew it all through with compressed air, and it seems to be venting just fine.
Test Drive #2 lasted only a half kilometer or so, and I lost power again.  Lifted the fuel cap, no difference, so not fuel starvation from the tank at least.
Nursed her back home again, pulled the plugs, and 1 & 4 were fueled up ( 2 & 3 looked great).
I'm getting spark at both sets of points, and at all plugs when I turn it over with plugs out - but obviously the bike is cool now.
I have a theory, but before I blow $$$ un-necessarily has anyone come across this or have any thoughts on other tests I can run please?
I'm nervous about taking it out on the road again as this hill I'm talking about will cause me a MAJOR PITA if the bike stops completely, as I currently have no way of hauling it around.
Hope you enjoyed the novel  :)
Cheers, Dave
1972 CB750K2
1976 Kawasaki Z900/A4
1976 CB750K6
1976 Goldwing GL-1000
1981 CBX Prolink
https://www.davewinfield.com
Offline newday777
Re: Losing 2 cylinders when warm - CB750K2
« Reply #1 on: March 04, 2025, 02:26:29 AM »
Yes that wouldn't be fun Dave.
You say you are getting spark at both points. Are they visably sparking while it is running in a dark garage?
Did you put in aftermarket points and condensers?
Have you tested the coils resistance when hot?
Have you tested the spark plug caps for resistance off the wires?
Did you clip off 5-6mm of plug wire so there is fresh wire to screw the plug caps back into?
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #2 on: March 04, 2025, 02:41:33 AM »
If you don't know how to do the tests Brickhouse Builds goes through them in this video, on a K2.
Stu
My current rides
Prior bikes....
Offline gotorx7
    • DaveWinfield.com
« Reply #3 on: March 04, 2025, 02:43:31 AM »
Hello again Stu  :)
I am seeing spark when opening the points manually. I'll try it with the thing running (will probably be a few days until I can get to it)
And No to all the other questions, but will follow those up next.
Thank you very much for the advice, you're worth your weight in gold  :)
And thanks for the video link, I haven't seen that one.  I will absorb it now!
Cheers, Dave
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline newday777
« Reply #4 on: March 04, 2025, 03:06:45 AM »
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #5 on: March 04, 2025, 03:12:00 AM »
Take your time Dave. I hope it is a simple fix for you. They are great bikes to play with.
Stu
My current rides
Prior bikes....
« Reply #6 on: March 04, 2025, 06:27:54 PM »
When you say "fueled up", what do you mean? Are those two plugs wet with fuel, but relatively clean, or black and wet, or sooty black and dry?
« Reply #7 on: March 04, 2025, 08:32:30 PM »
Hey everyone..
Cheers, Dave
Does this bike, by chance, have brand new condensors in it?
If so, get some old, used ones. They never wear out, despite being often changed. In the past 10 years or so, 100% of the condensors except the ones from TEC Japan (from Honda) are badly made, and fail in just a few minutes of run-time. This will act much like what you describe.
Offline gotorx7
    • DaveWinfield.com
« Reply #8 on: March 04, 2025, 11:34:56 PM »
The condensers do not appear to be new.  I'll check on the brand next time I'm out at the bike.
« Last Edit: March 04, 2025, 11:37:47 PM by gotorx7 »
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline gotorx7
    • DaveWinfield.com
« Reply #9 on: March 04, 2025, 11:37:18 PM »
Damp and dark, but not fouled..
1-4, left to right
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline gotorx7
    • DaveWinfield.com
« Reply #10 on: March 04, 2025, 11:41:23 PM »
Spark plug caps have about 5kOhm resistance, +/- 10%
Resistance between leads 1-4 and 2-3 is approximated 15kOhms.
There is spark visible at both sets of points with the motor turning over with the starter.
I'm about to head off for a few days. When I get back I'll put everything back together and run until warm and do some more tests.
Really appreciate the input and advice given, thank you.
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline newday777
« Reply #11 on: March 05, 2025, 01:29:31 AM »
Dave
Another thought, how are the fuel lines run, are there in line aftermarket fuel filters added and the lines run low below the carb bowls? Going up a steep uphill might get starvation with improperly run fuel lines. I've seen some people run their fuel lines way down under the carbs and have running problems. Had to ask.
Stu
My current rides
Prior bikes....
Offline gotorx7
    • DaveWinfield.com
« Reply #12 on: March 05, 2025, 01:35:32 AM »
Dave
Good thought!  That would explain it...
No filters, and the fuel lines don't drop down, they JUST reach the petcock..
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline newday777
« Reply #13 on: March 05, 2025, 02:12:36 AM »
Dave
Stu
My current rides
Prior bikes....
« Reply #14 on: March 05, 2025, 08:23:59 AM »
1-4, left to right
I would replace those two plugs.
Offline gotorx7
    • DaveWinfield.com
« Reply #15 on: March 05, 2025, 03:41:34 PM »
1-4, left to right
I have ordered some of the Nippon Densos,
Thank you!
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
« Reply #16 on: March 05, 2025, 06:46:37 PM »
Are the plugs all the same heat range? BTW, if a plug is damp, that cylinder wasn't firing. Given a lack of soot, suspect ignition.
Offline gotorx7
    • DaveWinfield.com
« Reply #17 on: March 11, 2025, 01:47:47 AM »
I agree.. I suspect the coils, as it is heat related, and I never heard of points or condensors being sensitive to heat (correct me if I'm wrong!)..
Anyway, I've ordered a few bits - new plugs, coil packs, leads and plug boots.      Also a chinese dynatek CDI copy to try if the coil packs/leads etc don't fix it..
Cheers, Dave
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
« Reply #18 on: March 11, 2025, 03:35:21 AM »
Condensers can d do fail when hot then recover
Offline gotorx7
    • DaveWinfield.com
« Reply #19 on: March 11, 2025, 04:26:16 PM »
Thanks Bryan,
I've never seen that personally but a good mechanic friend agrees with you, hence I bought the CDI.
My plan is to replace the coils, leads etc and if I still have a problem then do the CDI, rather than change too much at once.
Cheers, Dave
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline gotorx7
    • DaveWinfield.com
« Reply #20 on: March 18, 2025, 03:15:42 PM »
Update :
I've replaced the coils, leads and spark plug connectors with new units from Rick's..
For informational purposes, they are NOT a direct replacement (despite claims).. The coils are about an inch longer (but still fit thanks to the rear mount being movable).  And the Wiring supplied has two male connectors, not a male & female as per stock - I just used the old connectors.
Just waiting on new Spark Plugs and I'll fire her up.
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline gotorx7
    • DaveWinfield.com
« Reply #21 on: April 07, 2025, 09:40:35 PM »
And to close another one out  :)
I just couldn't get the points/timing combination right despite frigging around for many hours, so bit the bullet and bought a Dynatek clone..
With that fitted and timed (had a coupel issues getting enough adjustment range, but a file on the plate fixed that), the bike fired up right away.
I just got back from a ride to a beach further up the coast from me, and happy to report that it purred like a kitten - I am VERY happy now  :)
Attached are a couple of pics from my destination, Waitpinga beach!
« Last Edit: April 07, 2025, 09:42:11 PM by gotorx7 »
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline newday777
« Reply #22 on: April 08, 2025, 12:12:49 AM »
Good to hear you are back up and running great Dave
Stu
My current rides
Prior bikes....
Offline gotorx7
    • DaveWinfield.com
« Reply #23 on: April 08, 2025, 12:14:30 AM »
Thanks Stu, and for your help!
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
« Reply #24 on: April 08, 2025, 03:35:03 AM »
The issue to not get timing right could have been the advancer unit's springs. Too soft.
Both my CB750 have the springs cut. Cut one of the loops that attach spring to advancer. Bend out a new.
Used with points and Dyna-S.
Check if advancer has a play when the M6 nut is loose. Move max counterclockwards and tighten it.
Markings will be better, T at real TDC.
Redo the timing at ca 1200 rpm with a timing light.
You will notice a better more stable idle.
« Last Edit: April 08, 2025, 03:36:48 AM by PeWe »
Offline gotorx7
    • DaveWinfield.com
« Reply #25 on: December 05, 2025, 12:43:09 PM »
An update!
It's been quite a while, as I decided to replace the rims and spokes due to their poor condition.  Turned out to be a bit of a faff, but all done now, and very happy with the results, they have given the bike quite a lift in appearance.
Then when that got done and I started to put everything back together I found that I'd thrown out the little rubber exhaust balance tubes, and new ones took AGES to get to me.
When they finally arrived I was just about to head off on a 5-week holiday, and had purchased some more bikes (see my Signature!) which were keeping me busy so I never got around to a test ride.
FINALLY! got back from holidays this week, and got the old girl out for a ride, and WOW!  What a difference from when I got her, and she felt like I remembered a 750 should run, so very happy on that front too.   I have a couple of minor adjustments to do, including some fine tuning on the timing as suggested by PeWe but I'm now confident to get out and ride!
Thanks for all your suggestions and advice,really appreciated.   I'll get some more pictures up soon, and of the "new" 76 and the others.
Cheers, Dave
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline Deltarider
« Reply #26 on: December 06, 2025, 12:30:08 AM »
(sigh) All in all a disappointing thread. We have learned nothing, except that you've spent a lot of money on too many parts.
CB500K2-ED Excel black
Offline gotorx7
    • DaveWinfield.com
« Reply #27 on: December 07, 2025, 04:29:27 PM »
I'm sorry to have disappointed you.
I certainly learned a lot through the process, particularly that the problem was a faulty coil pack, that worked fine when cold, but failed when warm.  As I think I mentioned, I was a bit hampered with testing due to the inconvenience of having a driveway that is WAY too steep to push a bike up (most people struggle WALKING up it!) so was reluctant to road test until I was fairly confident I could get back home again.
But I have a bike that runs great now, and feel like the money I spent was well worth it.
Cheers, Dave
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline Deltarider
« Reply #28 on: December 07, 2025, 10:58:18 PM »
Cheers, Dave
I'm sorry you have missed my post on the simple DIY coil tester that anyone can make: http://forums.sohc4.net/index.php/topic,206147.0.html
Maybe it has been moved to 'Electrical' too quick where it may have drawn less attention.
« Reply #29 on: December 08, 2025, 07:48:31 AM »
Good experience to know.
"worked fine when cold, but failed when warm."
Offline Deltarider
« Reply #30 on: December 08, 2025, 01:35:56 PM »
That's why just measuring the coils' resistances is a bit trivial. A 10 min. bench test* is a better way to determine whether a coil is still good. The same goes for the condensers btw.
* If you run both coils in such a test - one after the other - you may point an infrared gun, to detect any significant difference in temperature. I have not done this myself yet, but I will in the future.
Offline gotorx7
    • DaveWinfield.com
« Reply #31 on: December 08, 2025, 01:43:17 PM »
Cheers, Dave
I didn't see that post, unfortunately.  One of the problems on forums like this is that there is a HUGE amount of information, and unless you know pretty much exactly what to search for, it is easy to miss.  Thanks for taking the time to create that post and I will refer to it in the future, no doubt.
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
Offline gotorx7
    • DaveWinfield.com
« Reply #32 on: December 16, 2025, 02:01:39 PM »
Just to wrap this thread up, I spent several hours riding yesterday, and the bike was a delight!
I am so pleased with the way it turned out, both visually and mechanically.
Thanks again, everyone, for all the help and guidance - it really is appreciated.
Now onto my K6 with everything I have learned :)
Stay safe!
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
« Reply #33 on: December 16, 2025, 06:44:12 PM »
That's a beautiful paddock of 750s!
:D
Offline gotorx7
    • DaveWinfield.com
« Reply #34 on: December 16, 2025, 10:44:13 PM »
Thank you!  And for all your help in particular!
1972 CB750K2
1976 CB750K6
1981 CBX Prolink
