Author Topic: 400 trouble  (Read 1100 times)
Offline Fred T
400 trouble
« on: March 04, 2025, 06:17:35 AM »
Hello, Im having an issue while ridding the bike, after about 10min the engine seems to flood or feels as it is running on two cylinders for about 30 seconds and then it will run fine again. This failure happens many times while ridding.
Any idea what could be causing this before I disassemble the carbs? I have drained the bowls and fuel seems fine, petcock filter is clean and also used sea foam to clean any possible dirt.
Offline denward17
Re: 400 trouble
« Reply #1 on: March 04, 2025, 06:27:12 AM »
Are you sure it is flooding?  See any signs of leaks or overflow?
Check your fuel tank vent, check your spark plug color.
Getting spark to all 4 plugs?
Offline Fred T
Re: 400 trouble
« Reply #2 on: March 04, 2025, 06:38:58 AM »
No leaks or overflows, the bike runs great until that happens. Will check later the tank vent and spark plugs.
Thanks
Re: 400 trouble
« Reply #3 on: March 04, 2025, 08:30:26 AM »
More likely electrical than carbs from description
Offline Tim2005
Re: 400 trouble
« Reply #4 on: March 04, 2025, 11:34:01 AM »
Are you running points or electronic ignition? I have had similar problems with electronic ignitions in the past
Re: 400 trouble
« Reply #5 on: March 04, 2025, 12:33:18 PM »
To check if the fuel tank's air vent is [rusted] closed or nearly so, just pop the gas cap loose every few minutes while riding and then close it again. If this stops the trouble, then the little air vent in the gas cap is rusty and sticking closed a little bit. A new gas cap (or a complete refurbish, though without the right tools) will fix it.
Offline Fred T
Re: 400 trouble
« Reply #6 on: March 04, 2025, 02:04:32 PM »
Running with Dyna S electronic ignition
Offline Fred T
Re: 400 trouble
« Reply #7 on: March 04, 2025, 02:06:34 PM »
Will try thanks
Offline Fred T
Re: 400 trouble
« Reply #8 on: March 04, 2025, 02:08:23 PM »
Re: 400 trouble
« Reply #9 on: March 05, 2025, 09:03:50 PM »
Argh...try taking off the points cover and taking it for a ride. If the Dyna triggers are dying (like both of my old Dyna S units did) they act much like that. If taking the cover off lets you ride just fine, or a lot further before acting up, they are in trouble.
Re: 400 trouble
« Reply #10 on: March 05, 2025, 09:15:30 PM »
Re: 400 trouble
« Reply #11 on: March 06, 2025, 02:32:02 AM »
I have read on here of several dynas failing that way
Offline Fred T
Re: 400 trouble
« Reply #12 on: April 09, 2025, 12:01:34 PM »
Crédit to Hondaman and bryanj, right on the money with the Dyna S , went to the old points and problem resolved.
Online newday777
Re: 400 trouble
« Reply #13 on: April 09, 2025, 12:20:39 PM »
Re: 400 trouble
« Reply #14 on: April 09, 2025, 08:12:30 PM »
Hey Fred, what are you going to do with the dead Dyna S ignition? I could use it for a science experiment. ;D
