Author Topic: Finally off to the printer!  (Read 2387 times)
Re: Finally off to the printer!
« Reply #25 on: March 12, 2025, 07:25:02 AM »
Congrats to you, Mark. I don’t have a 500/550 at the moment but something tells me I’ll still want the book! Cheers, J.
P.S. my ‘78 550K was my first “big” Honda motorcycle. It came after my 1970 Triumph T100S (500 twin, single carb) and I was blown away. The only thing I changed was the bars. My wife wanted higher bars of her 400F, so I swapped them. Both fabulous machines. Always on a Honda since.
Wow, you had a '78!?
I had a '78 550K, it had minor crash damage when I bought it.  Made repairs to it and then decided I like the F model better so I sent it down the road.  I didnt notice it being any faster than my other 550's and I didnt care for the exhaust on the late models ['77-78]
Offline drodg33
« Reply #26 on: March 12, 2025, 07:35:53 AM »
I am really excited to have this and cannot wait to purchase one.  I own a 72 CB500 and a 73 CB350F so the book will come in handy.   Looking forward to this.
I also have a 73 CB350F! Coolest bike Honda imported to the USA, IMHO (did you know Honda made a CB250F of it in Japan - all 17 BHP of it?). While I'm tempted to make another book while I rebuild it, I don't think it would sell very much as there aren't a lot of them around. Maybe if I had a 400F (but there's 2 types of those) it might make more sense? Maybe if I made it a smaller book it wouldn't be so expensive: the grease-resistant pages and covers are pricey.
Not many 350F for sure.  If nice they do sizeable money on Bring a Trailer.  I just read that they made a 250F !
« Reply #27 on: March 12, 2025, 07:43:12 PM »
Yeah, a lot of folks thought they were too "ballooney" in size (a common complaint of the 750K7/8, too), like a caricature or something. While I think Honda was walking the EPA emission tightrope with them, the last version of the 550K was the first one I found to run over 100 MPH. All of the "F" bikes would do it downhill, but on the flat they would reach up to 95-ish, and the last 1/4 throttle made no difference at all. If the float bowls were deepened a little bit (like 1mm more or so) they could touch 100 MPH when lying flat on the tank, but sitting up would drop them right back down. The 4-piper last version has a weak upper midrange (3/4-7/8 throttle range) because of the jetting: using the slide needles from the earlier versions of those PD carbs could fix that, but also ran the HC readings up past most major (USA) metropolitan allowances and could make them load up a little bit, fouling sparkplugs in slow freeway use. But, once past the 7/8 throttle range they perk up again, indicating the lean mix of the upper needle range (don't forget to back out the throttle-stop screw to get there...). Like most emissions-controlled bikes of that era, it takes a tricky (and patient) tuner to get them to run to the ton readily (heck, we were supposed to be going 55 MPH, right?). Many who just bore another 50cc into the engines to get there find that it doesn't stay there very long: as soon as the heat-cycling warps the 2 outer bores again the ton goes away, just like when they were new. 'Tis always better to step-bore these small ones, as the newfound power will stay there.
« Reply #28 on: March 12, 2025, 07:44:14 PM »
Wow, you had a '78!? I've only ever seen 1 in real life myself, so they are like rocking horse poop to me. They are (with OEM pipes) faster than the "F" model of that year due to the larger volume of the pipes, but needed the needles lifted a notch to make the midrange stronger - IF your local emissions gendarmes let you do it.
It was part of a trio. I painted my wife’s 1977 cb400F to match the 1978 550K and 750K.
Bravo, now that's CLASSY!
:D
« Reply #29 on: March 12, 2025, 07:48:52 PM »
Yeah, all 17 bHP of it!
There was one that popped up in a bike swap meet that Denver used to have every January (in the same facility as the famous Stock Show earlier that month), I don't think it is anymore. The fellow who bought it had a non-running 350F and thought he'd found a spare engine until he got home and noticed it was stamped "CB250-nnn...), but was otherwise the same as his 350F. He swapped in the engine and had to do some trickery to get his larger 350F carbs to fit into the smaller 250F intakes, but got it running! When I last heard of it he planned to leave it that way, as the 250F is even rarer than the 350F, and he only putted around with it anyway. He was a big guy, so it's work was cut out for it! :D
Offline drodg33
« Reply #30 on: March 13, 2025, 12:19:46 PM »
I tried to find a picture on like Google images and cannot find one.  Curious on what they look like.
« Reply #31 on: March 13, 2025, 12:52:55 PM »
17bhp, my first bike was a Royal Enfield Crusader Sports 250cc single which didnt even make double figures!
« Reply #32 on: March 13, 2025, 04:10:49 PM »
The pictures I have seen of them look almost identical to the US versions of the 350F. But, those pictures were also real, live, hold-in-your-hand Kodak size (color) pictures, so it was some time ago! It was gold, like the popular Candy Gold other bikes.
Offline drodg33
« Reply #33 on: March 14, 2025, 06:34:54 AM »
Fun....
