Author Topic: Rear wheel issues  (Read 695 times)
Offline Cruiser
Rear wheel issues
« on: March 08, 2025, 05:54:43 AM »
So I'm in the process of changing sprockets, chain, rear wheel brake, dampers, tires...
As I was undoing the bolts from the rear sprocket, I noticed that one of the bolts (stud actually) was loose... Even more so, it's broken off. So I reckoned, no biggy, I might drill it out and place a new stud. However... I can't seem to get the side of the wheel off (where the dampers are behind). If I'm not mistaken, you should just be able to lift the cover up, and access the dampers? I can't move it at all...
Any tips on getting that loose (it soaking in some WD40 now). I've tried putting the old sprocket back on and use it to pull on, or even tap on it. Doesn't budge.
It's always the "simple" things that seem to get in the way of a quick weekend job :P
Honda CB550 Four K3 1978
BMW R1150RT 2004
Re: Rear wheel issues
« Reply #1 on: March 08, 2025, 06:12:16 AM »
Would help to know what bike you are working on
« Reply #2 on: March 08, 2025, 06:38:43 AM »
might need a manual to tell you what you are working with
« Reply #3 on: March 08, 2025, 06:50:26 AM »
I've run into it on some 750 wheels that had been left outside for many years or in damp dirt floor sheds and the corrosion stuck the dampers to the posts.
You do need to have the old sprocket on so you can get hold of it while you stand on the rim, I've even had to get a bar to lever on a 2x4 on the rim and the sprocket. I might have added heat on the backside in the drum flat surface to heat up the rubber to help loosen the grip too.
« Reply #4 on: March 08, 2025, 06:52:32 AM »
On my cb750’s I also use a piece of 2” X 4” length of lumber. It’s about three feet long. Before removing the tire is easiest. Lay the assembly on the ground (sprocket side up). Use the wood like a crow bar, under the sprocket and levering down over the tire. Work your way around the tire and keep prying. When they really stick, get someone to stand on the wheel while you jump on the lever!
« Last Edit: March 08, 2025, 11:06:50 AM by BenelliSEI »
« Reply #5 on: March 08, 2025, 10:30:06 AM »
If its a 500/550 you need to unscrew te LHthread retainer ring
Offline Cruiser
« Reply #6 on: March 08, 2025, 12:39:23 PM »
Well the damn thing came loose... Flipped it around on some wood and we tapped it from both sides at the same time untill it started easing out mm by mm...
Was all gued together.
BMW R1150RT 2004
« Reply #7 on: March 09, 2025, 07:58:18 PM »
A year ago, I took a cb750 K6 apart that someone had packed with some sort of grease that had dried up. It took two of us to get it apart!
