Author Topic: Oil Sump Maintenance 400F  (Read 1796 times)
Online MauiK3
  • A K3 is saved
  • Old guy
Re: Oil Sump Maintenance 400F
« Reply #25 on: March 29, 2025, 07:48:09 AM »
In another 50 years you won't remember how you did it. :-))
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline grumpy56
« Reply #26 on: March 29, 2025, 06:12:20 PM »
Gasket is not right. Back holes do not line up and not enough material to enlarge them. Will make one I guess.
Related question: What is the purpose of the spring on the oil strainer? Seems as if it has no purpose.
Offline grumpy56
« Reply #27 on: April 04, 2025, 06:03:38 PM »
Used a NE brand oil pan gasket from 4into1 dry. Gasket is a bit thicker and can be "felt" when cinching bolts. No leaks!!!
