Author Topic: Sometimes undo what was done  (Read 1286 times)
Offline Gene
  • Chat enuf you too can be a
« on: March 29, 2025, 02:42:23 PM »
Just wanted to share this, sorry if it’s long.
1973 Honda CB 750 K3
My bike has been running great for 10 years, mostly because I bought it from someone on here and he’s a better mechanic than I will ever be.
Regular tune-ups, oil changes, all the 3k and 6k mile stuff.
A month or so ago I started getting some general rumbling and after fire, etc. could have been the change in the fuel brand, I thought. But, let’s go through the bike again. (possibly my first mistake)
Checked the fuel screen, fine. Checked the points, made a slight adjustment on 2-3. Replaced the plugs because why not. They’re cheap. Checked all the electrical-made sure of spark, etc.
Mind you, this was less than a week from me not knowing to check the draw on my battery during starting to know that the unit was done (again, saved by this forum).
So I went on my way and even reset the air screws on the carbs (turn to stop, one full turn out). I should say in between all these machinations I was starting the bike to see if anything got better.
It got good enough to get me back and forth to work and after a freeway run idled better than ever. Still was “poppy” in the morning though and at low idle. Didn’t start evenly.
Well, today I spent a little more time on it. Turns out I hadn’t adjusted the air screw for #2 back out all the way, the 2-3 points were set waaaay too close, and the 2 spark plug wasn’t set all the way.
This is all to say, when you think you’ve done everything, go back and look again. What was the last adjustment, what did you miss, what did you forget.
For those that read this far, I’m not talking about the certified geniuses on here, just talking about hacks like me. Sometimes, undo everything you just did and start over.
Ride safely
*1973 CB750K3 (Bow)
Offline Kelly E
  • Geriatric Hooligan
Re: Sometimes undo what was done
« Reply #1 on: March 29, 2025, 06:32:55 PM »
Grandpa used to tell me when I was stumped "go back and check the last thing you fixed".
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Gene
« Reply #2 on: March 29, 2025, 08:34:04 PM »
Exactly
*1973 CB750K3 (Bow)
« Reply #3 on: March 29, 2025, 11:34:44 PM »
When adjusting air or fuel screws, do not take for granted they all are in a specific position you know you had set before.
Always close them before setting them in a specific number of turns out.
I learned the hard way ;D
Bad condensers, loose and/or corroded connectors something that can just happen from one day to another.
Aftermarket connectors  on aftermarket cables/looms can have softer, thinner sockets that open up when the connection is slightly bent causing bad connection.
I have replaced the connectors for coils with other type.
« Last Edit: March 29, 2025, 11:38:48 PM by PeWe »
Offline Gene
« Reply #4 on: March 30, 2025, 02:51:21 PM »
So many little things, one piece of the puzzle doesn’t fit it throws everything off. I love these motorcycles
*1973 CB750K3 (Bow)
« Reply #5 on: March 30, 2025, 03:19:51 PM »
Bad condensors...
(Grrr....).
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: April 01, 2025, 07:26:55 PM »
Every once in a while I wonder about the idiot in my shop too…….. I think I mentioned the last job he did? Worked on the an original S/C “wrinkle tank” forever. Carefully vapour blasted and rebuilt the original (unique) petcock. Totally mystified when it leaked fuel all over the place, until I discovered the “wavy washer” on the wrong side of the selector plate……
« Reply #7 on: April 02, 2025, 12:15:07 PM »
Ah.
So YOU'RE the guy he worked for before he came to me.
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: April 02, 2025, 02:30:26 PM »
Ah.
I wish….. He’s still here!
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #9 on: April 10, 2025, 10:10:24 PM »
Bad condensors...
(Grrr....).
Ugh, that brings back memories.
10 years ago and didn't have a damn clue.
« Reply #10 on: April 20, 2025, 12:24:41 PM »
Bad condensors...
(Grrr....).
I think I remember your posts?
I made a box after that, which is labeled "BAD". That's where I kept the bad ones for about 5 years until I bought my new 20-ton hydraulic press and wanted to test it.
That was fun...
