Author Topic: Hard white carb corrosion!  (Read 693 times)
« on: March 31, 2025, 03:38:08 PM »
  Three of my K0 carbs had the dreaded white carburetor corrosion, it's not fluffy/white type, it's the gnarly hard deposits kind. I had a spare #1 so that leaves #2 and #4.
  They have done a few cycles through the ultrasonic cleaner and haven't improved a lot. A short soak in warm vinegar may have helped but no miracle cures are happening.
  Is it realistic to hope they can stay cleaned or are the bodies damaged enough that they will continue to corrode even if I get them cleaned up?
  Any other cleaning tips?
Offline spotty
Re: Hard white carb corrosion!
« Reply #1 on: March 31, 2025, 04:53:28 PM »
soda blasting ?
i blame Terry
« Reply #2 on: March 31, 2025, 06:26:27 PM »
In the past, I have just get off what you can and run them   If it is a cosmetic problem on the outside of carbs 1 and 4 well? what ya gonna do.  Actual carb cleaner that comes in a bucket (Gunk brand is the best by far imo)has gotten the most off for me, even that has not gotten all of it.  After some miles, have another look back in there, and it seems nice fresh gas takes away the white and leaves the damaged aluminum.  I have not had it effect the operation of the carb.
« Reply #3 on: March 31, 2025, 06:39:08 PM »
 Thanks, the combination of simple green, simply awesome and then a soak in vinegar reduced the white a lot but the finisher was just WD40, it seemed either to detach the white from the metal or maybe just disguise it. Thankfully the outsides are pretty nice looking.
 The set that I made from parts turned out nicer than the set I've been saving for a decade. Floats ordered, float valves not yet.
  Spotty, I considered the soda blaster, it's next if I'm not happy with the results so far. I got called in to work an election tomorrow so the carbs are rinsed and WD40'd.
« Last Edit: March 31, 2025, 06:41:33 PM by Don R »
Offline M 750K6
« Reply #4 on: March 31, 2025, 11:49:33 PM »
Autosol and a toothbrush.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #5 on: April 01, 2025, 07:01:05 AM »
I use this Stuff and then ultrasonic. They come out looking like new.
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #6 on: April 01, 2025, 07:46:45 AM »
Photo?
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #7 on: April 01, 2025, 04:31:42 PM »
Yeah, berryman's works ok...or you can use the Gunk brand for 15min., skip the ultrasonic, and they come out like new
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #8 on: April 01, 2025, 06:42:24 PM »
The Ultrasonic cleaner is critical for breaking loose debris in the small passages and orifices. I would never skip that step in a Carb rebuild. Berrymans loosens it up Ultrasonic get it out.
« Reply #9 on: April 01, 2025, 08:37:11 PM »
Actually, that is completely false.  Ultrasonic vibrations are only capable of penetrating less than a certain amount of mm into a passage drilled though a solid casting.  The larger the diameter of the passage, the further the vibrations can penetrate.  So if you think your ultrasonic is the ultimate weapon for idle air bleeds or the passages in your cv carbs, think again.  You basically are relying on a sink full of hot dishwater...which ironically enough is often all that's absolutely needed.
Ultrasonics are super convenient, neat, environmentally friendly, and generally even smell good.  The sound is mildly nerve grating, but hey, it's easily gotten use to or drowned out.  Generally a fabulous shop tool when you can throw parts in, set the timer, and get busy with something else.  They are not miracle workers guaranteed to solve all your problems.  Chemical problems still require chemical solutions.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #10 on: April 01, 2025, 09:00:25 PM »
We will have to agree to disagree on this one. Experience and Google are on my side.
Ultrasonic cleaners will unclog jets and passages where chemicals and compressed air will not
Please post what works for you not de- bunking what works for others.
« Reply #11 on: April 01, 2025, 10:10:24 PM »
that is what I am telling you...been doing this for 20 years now.  I have used every thing.  Gunk brand carb cleaner in the gallon bucket is THE best thing there is...cleanest, fastest.  It's horrible nasty chemical that burns your skin and is likely banned in several states, but damn it works good and does not remove the phosphorescent coating on old Keihin carbs or damage rubber parts.
