Author Topic: Shipping Honda CB750 parts from USA to Thailand  (Read 1810 times)
Online kyle750
Re: Shipping Honda CB750 parts from USA to Thailand
« Reply #25 on: April 10, 2025, 09:09:56 AM »
Originally I also believed that removing the inner sleeve was the next logical  step. But the OD of the inner sleeve is 20mm  and  close to 2mm thick on each side.  If the sleeve was removed the rubber bushing would have an inner diameter of 20mm which will then be TOO LARGE for the shock post at 17.5mm. Bushing is too small with the inner metal sleeve and will be too large with the inner metal sleeve removed.
Reusing the old Honda stock bushings will not work.  Inner diameter is perfect but the outer diameter is only 23mm and will be too small for the outer diameter of the KONI shocks eye which is 26mm.
Offline M 750K6
« Reply #26 on: April 10, 2025, 09:18:45 AM »
Find someone with a post drill to widen the inside of the Koni bush to suit?
Offline BenelliSEI
  • 1969 cb750
« Reply #27 on: April 10, 2025, 04:58:39 PM »
+1. Ream it out to the size you need?
Online kyle750
« Reply #28 on: April 10, 2025, 05:28:05 PM »
Measure the OD of thr metal bushing 1st
Thank You Gentlemen.  I will proceed to a machine shop to drill and widen the Koni inner sleeve.
« Last Edit: April 10, 2025, 07:40:13 PM by kyle750 »
