Author Topic: Fuel petcock(valve)  (Read 1635 times)
Offline malxerr
Fuel petcock(valve)
« on: April 08, 2025, 12:24:02 AM »
Kindly can you let me know if the Tank fuel valve is in the Res position or Stop position as shown in Picture.
Regards
Re: Fuel petcock(valve)
« Reply #1 on: April 08, 2025, 12:54:52 AM »
thats stop or off,straight down is on main tank,forwards is reserve supply.
Offline pjlogue
« Reply #2 on: April 08, 2025, 03:01:32 AM »
I would disagree with Dave500.  You can see the stamped "stop" on the holding plate that is facing forward.  The petcock in the photo is on reserve.
-P.
Offline jonda500
« Reply #3 on: April 08, 2025, 03:30:17 AM »
+1 yep, Dave has it right, that's off.
John
A starter clutch thread:
« Reply #4 on: April 08, 2025, 04:30:25 AM »
If you look very closely there is a small arrow pointing opposite to lever which is pointing at OFF
Offline CycleRanger
  • No comment about being an
« Reply #5 on: April 08, 2025, 05:33:02 AM »
You can download a PDF of the owners manual here:
It explains the petcock setting/positions and other useful information.  :)
« Reply #6 on: April 08, 2025, 11:50:31 PM »
-P.
the words on the plate refer to the actual thumb lever part,did they have reversed taps eleswhere?
« Last Edit: April 09, 2025, 12:04:19 AM by dave500 »
Offline pjlogue
« Reply #7 on: April 09, 2025, 01:03:24 AM »
-P.
the words on the plate refer to the actual thumb lever part,did they have reversed taps elsewhere?
My  appologies, I stand corrected.
-P.
« Reply #8 on: April 09, 2025, 01:31:05 AM »
no worries,that plate does have the stop marked in a different position,not a real clear photo though?if malxerr could post a new sharp clear photo it might show how the overseas ones got marked?,the levers action would be the same though,thatll be a 6 pack of cyber beers please.
Offline Oddjob
« Reply #9 on: April 09, 2025, 04:05:24 AM »
Easy way to find out. Takes off the pipes and the one position where it doesn't spill fuel everywhere is Stop.
« Reply #10 on: April 09, 2025, 07:50:51 AM »
It can be confusing, Honda could have done a better job at making it clear. And not all Hondas are the same?
On my Kaw, the handle is up for reserve, no question there.
« Reply #11 on: April 09, 2025, 08:20:13 AM »
In the first pic is the plate on upside down?
Offline Oddjob
« Reply #12 on: April 09, 2025, 08:22:09 AM »
If it was Bryan, the writing would be upside down.
Offline ZTatZAU
« Reply #13 on: April 09, 2025, 08:48:34 AM »
No! I don't think so.
The text is is upright but the labels run across the top of the plate rather than the bottom as in the picture Dave posted.
ZT
« Reply #14 on: April 09, 2025, 08:57:10 AM »
True to both, been a bad few days this end
« Reply #15 on: April 10, 2025, 07:55:28 PM »
In the years between 1974-1978 it seems like Honda went "petcock crazy".  If you have owned lots of Hondas from this period it seems every model and year had a unique, subtly different petcock! changing from one side of the tank to the other, mounting styles, different bung sizes, different numbers of outlets, and different layouts for the selector positions.  You have to read the fine print on every single one very carefully!
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #16 on: April 10, 2025, 09:07:36 PM »
+1 on this post about petcock crazy.
Most of my bikes are different.
All the petcocks were made by Keihin for Honda.
I'm sure there was collaboration and specs that Honda sent to Keihin to match the tanks.
The same Petcocks were used by other manufacturers.Kawasaki,Suzuki etc...
KZ400 Has the identical petcock as the CB350F
« Last Edit: April 10, 2025, 09:14:55 PM by Ozzybud »
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
« Reply #17 on: April 11, 2025, 12:02:46 AM »
That second pic shows spring washers for the holding screws thats a guaranteed leak through to carbs
« Reply #18 on: April 11, 2025, 07:02:15 AM »
+2!  I have a box of spare petcocks, but seems every time I need one I dont have the right type.
Offline carnivorous chicken
« Reply #19 on: April 11, 2025, 07:30:56 AM »
That is nowhere near a stock petcock for a CB350F. The fuel outlet comes out horizontally and at an angle, not vertically as in that one. They might work, but I think it would need some work in order to do so. There are also aftermarket 350F petcocks but they come with two outlets and also don't fit properly. OEM 350F petcocks go for upwards of $150 because they are rare and the only ones that work well on the 350F.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #20 on: April 11, 2025, 08:16:46 AM »
It's the replacement honda one that will work.(pictures are for reference only) The factory one has1 port not 2.
My point was that petcocks were made by Keihin for all Japanese bikes. And a original KZ 400 petcock is identical to a CB350F,1 port horizontal
« Last Edit: April 11, 2025, 08:26:51 AM by Ozzybud »
« Reply #21 on: April 11, 2025, 08:37:12 AM »
It's the replacement honda one that will work. The factory one has1 port not 2.
Don't want to get into an unnecessary argument, but for the sake of accuracy they definitely are not "identical."
https://images.cmsnl.com/img/partslists/kawasaki-kz400-1974-usa-canadamph-kph-fuel-tank7677-kz400-d3_bigkar095552464_4012.gif
https://images.cmsnl.com/img/partslists/honda-cb350f-four-general-export-fuel-tank-cock_bigma000079f11_07ef.gif
I've owned both 1974 bikes. They only overlapped one year, 1974, and the later KZ400 petcocks are very different. The earlier one might work (looks like they mount the same), but the fuel outlet comes out from a different spot at a different angle.
CB350F groups are full of people complaining about how non-original petcocks don't work, petcocks made for other bikes don't work, and how hard it is to find an oem one.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #22 on: April 11, 2025, 08:42:02 AM »
I stand corrected.
There is no need to argue I should have used the word similar.
My point being was that Keihin made all the petcocks and they were very similar in design.
An OEM unit is made by Keihin in a honda Bag or box.
« Last Edit: April 11, 2025, 08:45:41 AM by Ozzybud »
« Reply #23 on: April 11, 2025, 09:21:26 AM »
I think a lot of the bodies have the same or very similar shapes with various potential outlets -- some petcocks have what look like blocked or unused ones.
