Author Topic: Any reason why a TINY reg/rec wouldn't work? 77 750F2  (Read 725 times)
Offline xtravbx
« on: April 17, 2025, 06:33:52 AM »
https://www.ebay.com/itm/285944188513
Something like this?
Redoing a barn find 750F and am going to use a reg/rec combo instead of the stock stuff that is in place. Any reason why I couldn't use something like that, over say a Rick's unit?
« Last Edit: April 17, 2025, 06:35:24 AM by xtravbx »
Re: Any reason why a TINY reg/rec wouldn't work? 77 750F2
« Reply #1 on: April 17, 2025, 07:41:27 AM »
Not sure, I got my combo from Yamiya, it was listed as compatible with the SOHC 750 four.
« Reply #2 on: April 17, 2025, 08:25:12 AM »
That unit won't work with an SOHC charging system; there should be a black wire and a white wire for the regulator portion.
Offline xtravbx
« Reply #3 on: April 17, 2025, 08:30:55 AM »
Yeah missed that.
Needs field / ground / ignition etc.
I'll go with a Rick's.
« Reply #4 on: April 17, 2025, 10:54:08 AM »
That may work with a CB350 twin or the like?
Hmm...
Offline 700504
« Reply #5 on: April 17, 2025, 10:57:30 AM »
Also: The cheaper they are the lower the charging threshold, just saying from experience (Bought some $20 ones to test, idle volts: about 11v and change, revving engine to 3000 rpms: about 12.2v, and that was on a chopper with led lights)
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
  • I'm back
« Reply #6 on: April 17, 2025, 12:40:27 PM »
Any reason why you wouldn't just use the stock stuff that is in place?
Offline xtravbx
« Reply #7 on: April 18, 2025, 11:22:32 AM »
Just that its 50 year old electronics and not super efficient anymore.
I will run it for now. I have always had good luck with Rick's keeping my batteries in good shape.
Offline beemerbum
« Reply #8 on: April 18, 2025, 05:12:56 PM »
+1 re: Rick's
