Author Topic: Hole in the casting by the #4 plug  (Read 256 times)
Offline interstatewingrider
« on: April 17, 2025, 08:28:37 PM »
I picked up a 350-4 that's a little rough, and am trying to get it running correctly.  I cleaned out the tank (eew) and put in fresh oil and battery.  The #1 bowl overflowed.  I tapped it with a big screwdriver, and that stopped overflowing. It will start, but struggles to run.  There's no fire in #1 and #2. Those two pipes don't get hot.  Spark looks good.  I put new points in and adjusted them, and while replacing the plugs I found this hole in the head casting behind #4 plug.  It looks like it corroded through the casting.  It doesn't penetrate the cylinder, just the cam/valve assembly cavity.  I'm thinking JB Weld.
Have any of you come across anything like this?
Thoughts?  Comments?
Re: Hole in the casting by the #4 plug
« Reply #1 on: April 19, 2025, 06:46:03 PM »
 I'm not that familiar with that motor but I'm wondering if those holes were open to the fin space and a mud dauber closed them up for you.
 The carb main and pilot jets are extra tiny and tiny things can plug them up, especially when bad gas is present.
« Last Edit: April 19, 2025, 06:49:05 PM by Don R »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #2 on: April 23, 2025, 07:43:47 AM »
Lets see the bike?
1973 CB 750 K3
10/72 build Z1 Kawasaki
