I am happier than a clam at high tide that I finally got my '72 CB500 Four up and running, but I have a question about the cam chain - what does the UPPER cam bolt do?? I've adjusted the cam chain according to the manual with the lower adjuster, but when I start the bike there is a rapid 'ticking' noise, and I think it's because of the upper adjuster possibly making it too tight/loose? My valves are set perfectly at .05 and .08, so I don't think it's those.
When I had the bike apart and was wrestling with the cam chain sprocket, I noticed that when I turned that bolt IN/tightened it, it pulled the tensioner closer to the wall of the block; and conversely when I turned it out, it of course pushed the tensioner away from the block/towards the cam chain sprocket.
I haven't tried to adjust it yet - (it's 7:00am and these are the kind of things that wake me up) - but I think the ticking noise just has something to do with the adjuster(s), I'm just not sure if it's that or something more sinister...
