Author Topic: forged vs billet pistons, engine labs nicasil story  (Read 5170 times)
« on: April 18, 2025, 01:55:26 PM »
 This is a question I asked a while back and I read an article answering it.
https://www.enginelabs.com/engine-tech/engine/billet-vs-forged-pistons-manufacturing-processes-explained/
« Last Edit: May 19, 2025, 09:56:47 AM by Don R »
Re: forged vs billet pistons, engine labs nicasil story
« Reply #2 on: May 19, 2025, 11:07:32 AM »
I was interested in the Nikasil process as it is what is used in my billet blocks. A bit disappointed they don't actually go over the plating process...just the stripping. I have to think they send the parts out for plating. The Rottler honing machine is pretty cool.
« Reply #3 on: May 19, 2025, 11:32:08 AM »
 I kept watching for the plating process too, it's kinda in the title. There's still a little info about the repair and maintaining.
https://www.bing.com/videos/riverview/relatedvideo?q=nikasil%20cylinder%20plating&mmscn=stvo&mid=BB5E7D34D7B4209808B7BB5E7D34D7B4209808B7&ajaxhist=0
« Last Edit: May 19, 2025, 01:48:09 PM by Don R »
« Reply #4 on: May 19, 2025, 02:19:28 PM »
 Very, very short clip of Nikasil being applied. It makes sense as all my blocks came back with an olive green tint that I remove by bead blasting.
 https://www.youtube.com/shorts/jFHmtu6ObKY
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #5 on: May 19, 2025, 04:53:18 PM »
After watching that I got to wondering if we could remove the sleeves and Nikasil bare bored jugs.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
« Reply #6 on: May 19, 2025, 05:10:40 PM »
Think the casting will take it..?
Online willbird
« Reply #7 on: May 22, 2025, 02:29:01 PM »
A number of years ago at a past employer we had  a lab that made our CBN and Diamond grinding wheels. The process used an electric charge similar to how powder coating works, it made the diamond or CBN particles stand on end on the surface of the part, then Nickle was electroplated onto the part to hold them in place. This sounds like that in some ways. Then his Rottler makes them flat on top to be simplistic. The particles kind of slowly rained down onto the part in the solution so they would have to rotate the part so each area got "rained on". The electrostatic
Here is an example here.
https://www.cdtusa.net/plated
We would make the steel grinding wheel blanks some with a form profile to them, then the lab plated them. We made one solid carbide part that looked like a huge Lifesaver candy in some ways but it was solid carbide and 16" dia and 12" or taller. The diamond grinding wheel was used to grind the torus on the hole of the lifesaver. Having the whole process in house really helped us.
Offline simon#42
  • liverpool
« Reply #8 on: May 23, 2025, 02:47:15 PM »
The final honing of the cylinder should remove that
« Reply #9 on: May 23, 2025, 08:51:36 PM »
I'm thinking Mike means the green tint is on the outside after the bath in the solution.
Offline simon#42
  • liverpool
« Reply #10 on: May 24, 2025, 04:47:04 AM »
sorry yes you are right don , i get quite a few cylinders replated and they always come back bare alloy colour . the process is tough on the cylinders though it can only be done two or three times before the cylinder is finished .
« Reply #11 on: June 02, 2025, 04:15:43 PM »
Could it be bored and sleeved or does the process effect the metal?
Offline simon#42
  • liverpool
« Reply #12 on: June 03, 2025, 10:19:25 AM »
it affects the metal don , becomes porous . i think the damage is done removing the old plating . the cylinders i get plated are cast alloy i would expect a billet cylinder to be much more robust .
« Reply #13 on: June 03, 2025, 12:33:41 PM »
 That's interesting and good to know. A safely jetted street bike might be pretty safe as far as needing a re-plate.
Offline simon#42
  • liverpool
« Reply #14 on: June 03, 2025, 11:52:59 PM »
Yes I have bmw cylinders with over a hundred thousand miles on them and you can’t measure any wear . The two stroke racing cylinders are a different story !
« Reply #15 on: June 04, 2025, 01:02:28 PM »
That is some truth. 4 strokes it lasts a long, long time....skirts wear out first. Not quite as much oil in the system with 2 strokes
Offline simon#42
  • liverpool
« Reply #16 on: June 05, 2025, 09:07:32 AM »
they are also mostly holes mike , not much support for rings or piston .
Offline simon#42
  • liverpool
« Reply #17 on: June 05, 2025, 09:19:43 AM »
a 125 aprilia cylinder , makes nearly 60 hp
« Reply #18 on: June 05, 2025, 09:35:43 AM »
 Yep....more like transfer holes....not transfer ports. ;D
« Reply #19 on: June 05, 2025, 11:27:59 AM »
It looks like Swiss cheese!
Almost 60Hp is a lot for only 125cc.
I had a Zündapp KS125 1973 for a while in 1977. Maybe earlier. Blinkers on handlebars ends.
15-17hp was much back then.
The Honda CB125 B6 at the same time was very tired.
No wheelies as my Zündapp.
A friend had a Monark with a Sachs 125cc with 22hp.
So 60hp is a few times more. 2- stroke 60hp must fly away from a stock CB750 K ;D
Around 3 times more in modern bikes ;D
« Last Edit: June 05, 2025, 11:52:51 AM by PeWe »
Offline simon#42
  • liverpool
« Reply #20 on: June 05, 2025, 12:55:54 PM »
That cylinder is from a rsa aprilia 125 they where only made for gps and they were very very expensive . Only supplied to works supported teams .i have no real idea what they cost but as the cheap production racer the rsw cost 80 grand i would guess they were in the 250 thousand area . You still see the odd one for sale they go for around 40 grand . If you think that is expensive the last of the 250s cost a million pounds a year to lease . Thats one of the reasons they brought in a road based engine series to replace the 250s
« Reply #21 on: June 14, 2025, 08:28:27 AM »
 A friend was schooling me on the ford Gen 3 coyote iron cylinder, it gets a spray transfer process that seems similar to nicasil, it takes diamond hones and a special process to hone them. When done it almost looks like a mirror finish. He got some of his info from Ilmore racing.
Offline simon#42
  • liverpool
« Reply #22 on: June 15, 2025, 03:20:42 AM »
the first plated cylinders i saw where chrome plated , that was a mirror finish although some manufacturers used to put small dimples in the bore before it was chromed to hold the oil
